Need vac help
Old Aug 5, 2007 | 05:07 PM
Cdg2125's Avatar
Need vac help
Thinking of going back to stock from 00vi. Need some cash so going to sell the parts I have. Need help with vacuum lines tho. With the 00vi swap I have almost everything from the vac gallery t'd off and going to the 00vi. I was thinking that I could I could just put the hoses that were t'd off onto the USIM but it looks like there is only one spare nipple. The left side nipple is for the brake booster hose, the one in the is for PCV valve hose, and then there are other nipples I'm not sure what to connect. Next to the TB the is a 90 degree nipple that connects to the EGR purge canister. Under that is a skinny nipple. What attaches to that? Also, the skinny nipple above the tb is for what? Can the nipple under the tb be used for vacuum? Can I use any as vacuum points and T off hoses? Will they provide enough vacuum? Any thoughts about drilling the UIM to attach a new nipple? Thanks for the help and I'll post some pics if people need them. The FSM doesn't have good enough diagrams for me to go off so this is why I'm asking. Thanks again.
Old Aug 5, 2007 | 09:20 PM
Cdg2125's Avatar
well i figured out the vac setup again. After a while of sitting in front of the FSM and flipping things around on the computer I figured out the hoses to connect for the old vac gallery. Hopefully I can use it and get things back to stock...don't know tho. I guess this can be deleted/locked by a mod.
JonnyCum Lately
Nov 10, 2003 08:52 AM
csid
Sep 29, 2003 07:01 PM
NoMoreAlty
Jan 9, 2003 07:43 AM
