90 degrees and no air
Old Aug 6, 2007 | 08:59 AM
LILMAN's Avatar
THIS IS BULLSH*T. It started friday. It was like 90 out and I go to turn on my AC an nothing. I first thought that it was just blowing hot air out. After holiding my hand to the vent and feeling nothing I hit a bump in the road and boom. Crisp cold air. Then the same went on the weekend. Sometimes it just doesn't come on at all. My guess is a short in one of the wires, or a bad connection somewhere. Who can point me in the right direction to fix this?
Old Aug 6, 2007 | 09:06 AM
dgeesaman's Avatar
Maintenance Monster
Do you have an auto climate control? If so, follow the FSM procedure for manually testing the climate modes.
There is a single two-wire connector on the A/C compressor. If the wiring is bad, that's the point I would start to divide/conquer a possible electrical problem.
Dave
Old Aug 6, 2007 | 10:23 AM
aznprid972's Avatar
Double check the wire harness behind the climate control as well. That was my problem I had a while back.
Old Aug 6, 2007 | 11:12 AM
MOHFpro90's Avatar
My manual climate control went dead, and it didnt get cold. ofcourse, i coud control it, so that may not be your issue. Fan switch maybe? If you need one Ive got a working one. (if your manual of course).
Other than the switch...I'd agree with them on wiring.
Old Aug 6, 2007 | 07:06 PM
nissans13240sx's Avatar
check your a/c pressure switch
Old Aug 6, 2007 | 09:34 PM
maxpeed96plat.'s Avatar
I had a similar problem, next time it doesn't blow air..reach below the glove compartment and tap the fan/blower motor housing.. if it starts to run then it's prob ur blower motor going bad. If it blows cold air otherwise then I wouldn't be too concerned about the other components.
Old Aug 6, 2007 | 09:42 PM
SVI30's Avatar
There is a fan switch amplifier in the evaporator box. It is prong to open and short. Look thru the FSM and good possibility is this amplifier is at fault.
To the OP: I lived in Southington before moving to Calif. I bought a car in Elmwood.
Old Aug 7, 2007 | 02:34 PM
TRINIMIKE's Avatar
Fan Switch Malfunction
Hey Dude my today my AC only works/ when I trun the fan switch to III or IV, other than that it does not come on! Could it be a bad fan switch. I already checked the fuse(S), which were fine. What could be the problem?
tarun900
19
Dec 20, 2021 06:57 PM
aw11power
Oct 10, 2021 04:57 AM
Miket2006
Mar 1, 2021 03:55 AM
Justin Kroll
Oct 1, 2015 07:03 PM
MichMaxFan
Sep 30, 2015 09:18 AM
