Drivetrane problem (no go)
Has his VINs memorized
Ok, headed to work this morning and shifted into fifth and heard a nice loud POP and all of a sudden RPMs and Speed fluctuate with ease just by pushing the gas. Just like on ice. From what I have been able to see the tranny is still in one peice but not 100% sure of it. When we loaded it onto a trailer it was leaking gear oil very steadily. Car starts and runs fine. Even shifts good into gears but it isn't getting to the wheels somewhere as if the clutch is stuck open. Any ideas guys? I was thinking the throwout bearing arm maybe? I'm going to try to get underthere and look at at least the outside of the trans tomorrow night.
Thanks!
Thanks!
The drivers axle is not in the tranny 100%. You may just need to pop it back in or you stripped the splines off where it meets the differential and youll need a new axle. Its pretty common for the C clip to no fully engauge into the differential. I have seen it before after a clutch job was done.
yeah, crap all I've got is napa brand! I had redline MT-90 in there. It does sound much more reasonable than what I was worried about and everything fits. When Iget home tonight I'll tear into her and see for sure. Thanks for helping guys! I'll post up after I check it out and/or fix it.
Alright guys, I found out what it is!!! You were close Jon. It was an axle but it was the passengers. The bracket that holds the middle of that axle snapped off and allowed the axle to slip out of the tranny. Anyone reading this have one of those on a car they don't need? It's a 5spd. I don't think I need the bolts but I'd like to get em. If you guys know anyone who might have this part PLEASE PLEASE PLEASE get in touch with me! I need it ASAP.!!!! I'm going to post this in the classified section as well. Thanks!
Jon, you think the auto is same as a 5spd? If so I'll try to find a ride down there and grab it. (the camaro broke down too!)
No way you're getting rid of it for free though!!
Dude, I'm mystified about how the heck I broke it!! I'd never have thought I'd see or hear let alone it being me that had one break!!
AWESOME!! I'll try like heck to get down there ASAP and get it. Shoot me a price too man.
The ABS ring is on the outside anyway and I think mine is still good... The pass axle in your 99 is shot isn't it..?
Whew!! Got it fixed! It was just the carrier bearing, splines on the shaft were fine. Although I did bust up my oil press sending unit but no biggie! Clutch feels better than it did before it broke the other day too. Major thanks to Jon, you're the best dude!
Originally Posted by JSutter
have fun with the y pipe in the way?
Oh, you were right, those sunroof shims are very easy to get to! I'm going to try to get some tomorrow so I can finally fix that darn thing!
But yeah, thanks for saving my butt again! It was good to get back down there.
Ok, got some pics from when I fixed the problem. The whining sound didn't go away however. So I'm nervous about that but I'll get to it soon I hope.
Here's on of it still on the car.
The old still on the axle and the new. Pretty clean break right at its weakest points, but still... It's a pretty rugged part!!
Here's one of it completely off the car both peices
The pass axles are the same for all 4th gens, auto, 5spd, open diff, LSD it doesnt matter. the abs ring in the only difference.
Originally Posted by fanaticrockford
The axles are the same but the bracket is different from manual to auto.
Originally Posted by ti2tmax
Hmm, I don't know... The new bracket was from Jons parts 99 auto and it fit perfect on my car which is a 99 5spd. I think they had different identifying numbers on them but they seemed exactly the same, and fit exactly the same.?
Post #18 and down.
It was a post by nismo.
http://forums.maxima.org/showthread....ghlight=manual
Heres a similar one by him.
Hmm, interesting. So far mine is good, fit perfect and is working perfect. Although I do have a whine but I don't belive that is it. I'll get a manual one and do a comparison. I had both parts together, but I probably wouldn't have noticed an angle less than 3 degrees though. I'll check for leaks etc. Thanks for that info
litch
123
01-04-2024 07:01 PM
jmlee44
10-02-2022 02:13 PM
HerpDerp1919
09-29-2015 02:02 PM
