slippin clutch
Old Aug 7, 2007 | 08:18 PM
Maxima-4DSC's Avatar
YoU CaNt SeE mE
slippin clutch
do ya think the salve or master would allow a new broken in clutch to slip.....seriously i was pushin my car hard the other day and at a traffic light i got plumes of white smoke from burnt clutch...lol
Old Aug 7, 2007 | 08:20 PM
maxima985spd
My clutch is broken in about a couple months old and it slips once in a while usually in 4th gear. I don't know wtf is going on
Old Aug 7, 2007 | 09:36 PM
Snypa's Avatar
Omfg.........think the clutch flu is coming back to haunt us 4th's.Goodluck guys.Guess purchasing a new one will do the trick.
Old Aug 8, 2007 | 12:30 AM
96blkonblkse's Avatar
Did you replace the rear main seal? There could be an oil leak, thats starting to leak onto the clutch disk.
Old Aug 8, 2007 | 01:32 AM
S1cTech's Avatar
^mmhm.. could be that... depends on smell too...
Old Aug 8, 2007 | 10:42 AM
maxima985spd
I don't think I'm leaking anything. I will check smells and/or leaks.
Old Aug 9, 2007 | 07:17 AM
JtzMax's Avatar
Whatchyou say?
my clutch slips every now and then ... but I just chalked it up to being "normal" for my car. most of the time it does it as I shift. I am not slipping the clutch on purpose, just shift like normal, but I can feel it engage after my foot is clear off the clutch. like it wants to seat, but it's not sure so ... it takes a sec or 2 to do it.
gotta do a re-build soon anyway ... so I will do a new clutch then too. although this one feels good otherwise!
Old Aug 9, 2007 | 07:31 PM
YoU CaNt SeE mE
welll when it hits 3000 thats when it starts to slip. what a POS.
Old Aug 11, 2007 | 05:46 AM
KrayolaSE-L's Avatar
Well I'm still on what I believe is the factory clutch, and at 108k in my '95, it seemed to only slip sometimes when it wanted to and ONLY during shifting. Stopped for a while, but my car seemed a whole lot slower. Finally got it scanned and had a bad knock sensor and a bad 02 sensor (much to the displeasure of quite a few other maxima's that had been running there mouths about how I wasnt that much faster than them, but I digress). Fixed the knock sensor and got a whole lot faster, but clutch started slipping again.
Anyway, point is, most people in this thread with a stock clutch might consider checking there fluid levels/ bleeding the clutch to make sure there is no air in the line. If there isnt, might be time for a new clutch. And for those people with new clutches, I'd either say rear main seal, input shaft seal or you just didnt break it in properly.
Old Aug 11, 2007 | 06:09 AM
JtzMax's Avatar
Whatchyou say?
breaking it in just means dupping the clutch at like 6,500 RPM ... right? lol
Input shaft will make other noise (as I know now from experience - need a rebuild) and if it is leaking that bad ... it'll make a puddle (or at least drip). For checking the fluid levels ... not a bad idea, but that is just gonna make it hard to shift - not cause white smoke. The main would also cause leaks to be noticed and also low oil levels.
I'd say you smoked the clutch yourself ... 1/2 peddal on release maybe ... my moral is .. learn to drive a manual trans!
Old Aug 11, 2007 | 06:59 AM
You're right about the original poster. But I was more or less addressing the other issues in the thread. My clutch on the other hand is just old. Seen the track a good few times. Just time for a new one.
And also, a main leak might not necessarily mean low oil levels. I mean yeah, over time of course but a week or two might not be a noticeable difference given a few factors. (But feel free to correct me, I'm speaking from some personal experience myself, although not directly related to a oil leak)
Old Aug 11, 2007 | 07:05 AM
crazymuppit's Avatar
you shouldnt of been able to make a brand new clutch slip unless
a. You didnt break it in properly
b. You didnt assemble it properly
c. You dont know how to drive stick
d. Youre pushing massive power
my exedy stage 1 with about 10000 miles on it wont even come close to slipping even if i DID dump the clutch at 6500 (never would).
user 11122324
42
Jul 18, 2022 03:35 PM
Mar 12, 2020 12:06 AM
spencerwh1
Jun 30, 2016 05:44 AM
BkGreen97
Apr 2, 2016 05:47 AM
carlosvq30
Sep 26, 2015 09:44 AM
