Ebay sts, take a look and input
Old Aug 7, 2007 | 11:37 PM
97maximaman's Avatar
http://cgi.ebay.com/ebaymotors/ws/eB...MEWA:IT&ih=010
This is the link to the short throw i was thinking about picking up. Since i'll have the whole exhaust off in a week or so it would be stupid not to do this. My question, anyone tried these ebay ones, i thought someone said they worked but im not throwing it on without being sure.
Old Aug 8, 2007 | 12:07 AM
Tmcgradyfann1's Avatar
close but no cigar
nice item, quick shipping, great ebayer, thanks
Jul-16-07 08:52
89 90 91 92-98 NISSAN 240SX SR20DET NISM0 SHORT SHIFTER
_---------------------------------------------------------------------
Very understanding, especially when I messed up the payment. Thank you so much!
Jul-13-07 20:31
95 96 97 98 99 00 01 NISSAN MAXIMA NISM0 SHORT SHIFTER
quick shipping, not nismo shifter, box was damaged, u pay for what u get.
Jun-29-07 10:46
89-98 NISSAN 240SX S13 S14 S15 JDM NISM0 SHORT SHIFTER
Great product.
Jun-26-07 04:40
didnt exactly fit . kinda tore up my synchros
Jun-18-07 09:10
item was brand new as promised, A++ thanks!!
Jun-13-07 09:56
95 96 97 98-01 NISSAN SENTRA 200SX NISM0 SHORT SHIFTER
Love the short shifter.A++++++++
May-27-07 15:40
well basically i just went through 90 pages and spent 30 minutes of time and viewed their feedback and found all the nismo short throw shifter feedback i could and this probabl
y wont help your decision at all.
Old Aug 8, 2007 | 12:09 AM
Fadrvr's Avatar
I think that the short shifter falls into the catagory with strut bars, as long as they are not made by pixi sticks it should be fine.
Old Aug 8, 2007 | 05:38 AM
maximus_pr's Avatar
first nismo don't make any parts for the maximas so is not a nismo product
second its been disccussed a million times this is not a short THROW shifer this is only a shorter stick period read here for what a real STS is
http://forums.maxima.org/showthread.php?t=255634
Old Aug 9, 2007 | 07:33 AM
JtzMax's Avatar
Whatchyou say?
Get the Ebay shifter ... you will be happy enough. It is not a "Nismo" part, but it's a decent shifter - had mine for a while now and no probs. Also, it did make the shifter sit closer to the top trim by the ashtray, but it doesn't hit even under hard shifting. I like it ... all I am sayin! :P
Maximus_pr ... I am not sure that the base of the shifter can varry too much, it must remain the same so it hits the same pegs in the trans. With our cars, we use a rod linkage system and if the base were different, it would push the rods out of place (I would think anyway). I think it is a shorter shift due to the length and the fulcrome (<-- ?spelling) point. I see it like this ... if you have a lever that is 10" long and you move it down 10" and compared that to a 5" lever moving 10" ... it's shorter no? Not trying to bust ballz here ... but I don't understand how it could be a shorter thro otherwise.
Cheers!
Old Aug 9, 2007 | 12:21 PM
Alright, i had the same theory about the shifter as you, its a lever with a fulcrum, move the fulcrum up and the throw is less. Pretty basic geometry. Did the one that you bought say nismo out of curiosty. Did it have all necessary replacement parts, or is it litterally just a rod, and you transpose all parts?
Old Aug 9, 2007 | 01:31 PM
tong's Avatar
Shortened my throw, in fact I even compared the two side by side and you could easily tell it was taller from the ball to the linkage arm. In fact next person to buy one please take a picture of it right next to your stock one. Is it a HUGE difference? Nope, Is it a big difference? Yes.
To the OP, search around this issue has been hit on a lot lately.
Old Aug 9, 2007 | 01:39 PM
darklegend06's Avatar
Well I had a similar one to that except mine didn't have the nismo decal on there.
I had problems with 1 3 and 5th gear cause it would always hit the shifter trim, eventually the corner of my shifter trim chipped off.
The height of the shifter is close to stock height but the bottom (shifter ball down) is lengthened for the short throw shifts.
Eventually I went back to stock and did what Kevlo911 did. (see sig for the link)
Old Aug 9, 2007 | 02:53 PM
I get what your saying about it hitting, but u could have just had any machine shop bend the upper part slightly backwards, and for like $5!!!
Old Aug 9, 2007 | 04:01 PM
JtzMax's Avatar
Whatchyou say?
No ... just turn the thing around. It will hit if you put it in "backwards" but if you put it in just like you take the old one out, you're good. I didn't have any problems doing mine, some ramps a 12mm (I think), some time, and some sweat and it's in. If you do it "right" you replace the ball inside the shifter - dang it I can't remember what it's called.
The one I bought off ebay said Nismo on it, same rod in fact. It came in an envelope in the mail ... just the rod! No head but it did have some grease IIRCC. The metal ball on the rod sits inside a plastic housing that is split in 1/2 to fit around the metal ball. This is the part that people replace for smoother shifting. Make sure you use the grease, or the plastic will bind your shift points. It's a 6-7 / 10 job to do ... but really once it's done, you'll like it!
Cheers !!!! PM if I can help ya mate
Old Aug 9, 2007 | 04:10 PM
1chewabacha1's Avatar
Don't get it if you are putting on a universal shift ****. The metal is weak and the **** screws just eat right through. Eventually you'll have to tighten the screws all the way through until you have no more metal to go through.
Had it for 3 months.... Shifted fine.... Threads started to go through but I didn't mind. What I did mind was the fact that the shifter actually snapped in half while my brother was driving my car!!!!
He said he was throwing the thing into gear kinda hard but come on!!!!
Solution: Put the stock shifter back on, cut down 4 inches or so, and voila, same effect, stronger material (my bro has driven it hard plenty of times in the last couple of months)
Old Aug 9, 2007 | 04:49 PM
Moral of the story....Don't let your bro drive your car, don't ever let anybody drive your car!!!
Old Aug 9, 2007 | 07:52 PM
JtzMax's Avatar
Whatchyou say?
you had a bad shift **** then mate .... my Razo is just fine. It came with an insert that you screw into the bottom of the ball, then the insert threads onto the shifter.
Old Aug 9, 2007 | 09:41 PM
ThurzNite's Avatar
How do you put in the shifter "reverse"? Wouldn't that put it too far back?
Anybody not happy w/their shifter cuz it hits the front console? I'm looking for a used shifter. Thanks.
Jae
Old Aug 10, 2007 | 03:44 PM
Max Noob's Avatar
i dont think short throws on the max help with shifting any. when i had mine it it make the throws harder and less responsive than stock under hard fast shifting. even if you doing it for looks, the sts arnt even as low as you may want. i ended u getting my stock shifter cut a few inches and welding back on the top part with the screw threads. shifts much better and feels much nicer.
Old Aug 10, 2007 | 09:40 PM
ThurzNite's Avatar
I need it to move the shifter forward cuz I'm using a 5th gen tranny. I could care less about the shorter throws.
Jae
Old Aug 11, 2007 | 06:29 AM
JtzMax's Avatar
Whatchyou say?
Thruz .... using a 5th gen trany will push the stick back because the way the shifter works. (rods vs cable linkage) .... so if you get a 5th gen shifter (which you'll need) you will not need to move the stick forward or back, it fits.
When using a 4th gen trany and a STS, yes it puts the shifter forward of your "normal" shift points, but it does not hit the trim. Maybe mine is in backwards ... and that is why it sets forward. Maybe if I put it in the other way around it would hit the back trim ... ??? Not gonna take it all apart to find out anyway! Nobody I know has a problem with their STS hitting trim at any rate .... so buy it, if you don't like it ... it's 20 - 30 mins of your time to replace your stock one.
Old Aug 12, 2007 | 01:05 AM
ThurzNite's Avatar
Has anybody compared the 4th and 5th gen shifters?
Jae
Old Aug 12, 2007 | 09:37 AM
my stock shifter is almost flush with the trim. Love my stock cut sts compared to that ebay crap I got.
Old Aug 12, 2007 | 02:44 PM
Hey man. Would you let your bro drive your maxima if he let's you drive his 327 AWHP Evo???
Old Aug 12, 2007 | 09:09 PM
KStoAZ's Avatar
its not a Short throw shifter jsut a shorter shifter and they snap on u at the worst times, ive heard stories hahaha just invest in the b&m or somethin like it so u dont have to worry about ****
Old Aug 13, 2007 | 07:20 AM
Flava_24/7's Avatar
Boosted Panda
It is a short shifter. The height however will not be much different then OEM. The throws between gears will be much shorter though.
Now the snapping is something Ive heard about as well. I previously used an OBX shifter and it woked fine for me. I had it for many years. I currently swapped out to a B&M replica to see if there was a difference in them as far as shifting goes and there wasnt.
Old Aug 13, 2007 | 11:33 AM
Thing is im not really sure what i want, i mean a shorter throw is cool, but im not racing. And what i really need is a shorter shifter to accomidate a flip out screen. I'll be putting a gps module in with a screen. Unless theres a non flip out screen that fit with the car but i dont know much about that.
Old Aug 13, 2007 | 12:16 PM
Flava_24/7's Avatar
Boosted Panda
How big is the screen?
It should fit without hitting the shifter. If anything just mount it in the top slot.
Many have flip out screens with no issues,
litch
123
Jan 4, 2024 07:01 PM
gigabyte
Jan 6, 2017 06:05 PM
magiconthetire
Oct 26, 2015 09:03 PM
220k+ A32
25
Oct 3, 2015 09:09 PM
soybeanz
Sep 25, 2015 10:46 AM
