Possible to fix hood struts/supports?
Old Aug 8, 2007 | 12:47 PM
fast97maxse's Avatar
My hood struts/supports no longer hold the hood up.
Sure, I can put a stick in place when it's open,
but I shouldn't have to, and it looks harfarsed besides.
Does NE1 know how to fix or maybe "recharge" them?
Or do I have to replace them?
If it's replacement, where's the cheapest place to get them,
how much am I looking at?
Would some from, say a Dodge work (and be cheaper)?
Old Aug 8, 2007 | 01:16 PM
BlackCat's Avatar
RIP '98 Maxima SE
You're better off buying replacements. Check ebay.
Old Aug 8, 2007 | 01:18 PM
pmohr's Avatar
No more Maximas...
I 'fix' mine with a pair of vicegrips.
Old Aug 8, 2007 | 01:19 PM
slinky87's Avatar
yea or just go to autozone youll also need a 11mm open end should take you about 10 minutes to replace
Old Aug 8, 2007 | 01:24 PM
maximized98's Avatar
Addicted to the Org
Yep, Autozone. 19.99 for each. Lifetime replacement too!!!!!!
Old Aug 8, 2007 | 01:35 PM
ThurzNite's Avatar
I got 1 from the junkyard. It's on amazon.com now if u want.
Jae
Old Aug 8, 2007 | 02:02 PM
Neo Raven456's Avatar
I'll trade you my good ones for your busted ones. PM me
I just installed a carbon fiber hood (~50lb's lighter than your hood) and my good struts will crack my hood, but yours will work perfectly
Old Aug 8, 2007 | 02:16 PM
SmurfLeech's Avatar
Don't purchase cheap hood struts from eBay. Those are known for breaking after a short while.
Go with some stock struts if possible.
And no, you can't "recharge" them.
Old Aug 8, 2007 | 06:57 PM
goldmax's Avatar
I got the lifetime version at Autozone, and have had to swap them out about 3 times. They die about every two years. Just make sure you keep the receipt.
Old Aug 8, 2007 | 09:16 PM
99grnmaxgxe's Avatar
Autozone>eBay in this case.
Old Aug 9, 2007 | 06:18 AM
Thanks for the suggestions.
Guess I'll get them from autozone.
I expected they'd cost much bucks but $20 per isn't bad.
The vicegrip idea is a good one meanwhile.
Neo Raven456 - are you ever up around Danbury CT?
I'll save the old ones for you.
Old Aug 9, 2007 | 06:53 AM
JtzMax's Avatar
Whatchyou say?
Good luck getting the ball joint that they mount to. I can't for the life of me get mine off the strut, can get the strut off the car, just can't get the ball out. Some struts come with the ball, some don't. I made the mistake of buying the kind that did NOT come with the ball. The stealership is C R A Z Y with what they want for EACH ... like $15 per ... that is $60 for 4 ball joints 11mm ... so, moral is that I use my stick and I am happy just fine! lol
Old Aug 9, 2007 | 07:01 AM
G4nismo's Avatar
Originally Posted by fast97maxse
"recharge" them?
there not batteries. lol
go to advance auto. lifetime warrenty ftw
Old Aug 9, 2007 | 02:57 PM
never, I'm on a family trip at the moment in maine, don't want to disturb them and sidetrack on the way back to NJ. Thank you though
Old Aug 9, 2007 | 03:10 PM
VTonmymind's Avatar
Mmm, fresh lobster
That's what I've got going on too. Reckon one of these days I'll get some struts, but the grips work just dandy for now.
Old Aug 9, 2007 | 03:27 PM
pmohr's Avatar
No more Maximas...
A few times I had the vice grips set too tight, now the strut body will catch on the piston and actually support the hood's weight on that marred surface (for about 10 minutes, found out the hard way just like how I found out my shocks no longer worked...).
Old Aug 9, 2007 | 07:00 PM
ChubbieBoi's Avatar
i had to replace my the other day. Bought it at Advance Auto Part. $20 each. very easy installation, i thought it going to take me forever to put them on.
Old Aug 9, 2007 | 07:20 PM
WhiteA32's Avatar
Anyone use these hood struts in the trunk and remove the torsion bars?
I would love to this
Old Aug 9, 2007 | 07:50 PM
JtzMax's Avatar
Whatchyou say?
beed done ... search
Old Aug 9, 2007 | 11:15 PM
VIP Maxima
autozone has ****ty ones too. work about 5 hours of open hood.
Old Aug 9, 2007 | 11:47 PM
MaximaDvr's Avatar
got mine from autozone about a yr ago now and they still work flawlessly. They basically lift the hood by their self after i lift it up a little with my hand. I believe they were the "Mighty Lifts" brand.
Cheap and easy installation.
Old Aug 11, 2007 | 05:24 AM
SE Maxima's Avatar
i also got some from autozone, installed over a year now and still working fine. the install takes about 10 mins...nothing hard about it with a few basic tools.
Old Aug 11, 2007 | 11:00 AM
Max Noob's Avatar
i think stock set was 150 for both from dealer. huge rip off. go autozone.
Old Aug 11, 2007 | 11:35 AM
VIP Maxima
OEM hood struts are NOT a rip off. they last 10x more than autozone's $50 junks
Old Aug 11, 2007 | 01:03 PM
96DentKING's Avatar
It's already been said but the much less expensive "junk" has a lifetime warranty Once they break you bring them back to Autozone and they'll recharge them for free!!!!!!
Old Aug 11, 2007 | 01:06 PM
VIP Maxima
it DOESNT have a life time warranty.
Old Aug 11, 2007 | 01:13 PM
AceofSpds's Avatar
wat
warranty is probably against defects, not normal wear and tear
Old Aug 11, 2007 | 01:44 PM
96DentKING's Avatar
The reciept right in front of my face begs to differ. 1+ years on the autozone struts with plenty of hours on them. still going strong.
Old Aug 16, 2007 | 09:41 PM
Maximas's Avatar
2DA MAXX
My experience with the Autozone ones didn't last either.
Old Aug 16, 2007 | 09:49 PM
WhiteA32's Avatar
Its complicated.
Basically it means, you can bring it in and exhange it ONCE. Then you have a 90 day warranty.
Old Aug 17, 2007 | 02:14 PM
Mctwist77's Avatar
Check out a junkyard, thats where I got mine
Miket2006
Mar 1, 2021 03:55 AM
AaronL
Aug 8, 2020 10:31 AM
howardis
Dec 11, 2019 06:10 PM
Unclejunebug
Apr 2, 2016 05:42 AM
leatherneck
Sep 30, 2015 09:16 PM
