Car started dying on me this morning - idles real low
Jul 20, 2001 | 08:42 AM
There may be too many causes for this problem to get a simple answer on, but I'll try it anyway. My car suddenly started dying on me this morning. It was fine yesterday. I did replace my intake 2 months ago and messed up my MAF sensor, but I went back to the original intake and repaired the MAF sensor. Everything has been fine for 2 months now. Now it's idling very low and keeps dying at intersections. I know how to increase idle, but I imagine there is an underlying cause to the problem and it's just the symptom of a sensor that's gone out, or a vacuum leak or something. Can anyone comment on this, or are there too many variables to answer without seeing the car?
Thanks,
Van
Jul 20, 2001 | 09:14 AM
IACV-AAC
Quote:
Thanks,
Van
Here is some text copied from the factory service manual.
"Idle Air Control Valve (IACV) -- Auxiliary Air Control (AAC) Valve
This system automatically controls engine idle speed to a specified level.
Idle speed is controlled through fine adjustment of the amount of air which
by-passes the throttle valve via the IACV-AAC valve. The IACV-AAC valve
changes the opening of the air by-pass passage to control the amount of
auxiliary air. ... "
You may make a quick test of your IACV-AAC in the following way. With the
motor at normal operating temperature, and at idle, switch the A/C from
"off" to "maximum". Keep your eye on the tachometer as you do this. The
idle speed should dip momentarily and then recover. If it does this, the
IACV-AAC is working. If the idle drops and does not recover, the engine
may stumble, falter, and stall. The IACV-AAC may require cleaning,
adjustment, or replacement.
The correct idle speed is...
- 700 +/- 50 (automatic transmission, in Neutral)
- 625 +/- 50 (5-speed)
Here's the factory service manual component inspection procedure for the IACV-AAC.
1) Make this test with the ignition key OFF. Disconnect the IACV-AAC valve harness connector.
2) Looking into the valve connector with the latch at the top, you will see two rows with three terminal positions in each. They are numbered 1-3 (top row, right to left) and 4-6 (bottom row, right to left). Check resistance between the following terminals.
2 and 1.
2 and 3.
5 and 4.
5 and 6.
At a temperature of 68 F, the reading for all measurements should be approximately 30 ohms.
3) Reconnect the IACV-AAC valve harness connector.
4) Remove the idle air adjusting unit assembly (IACV-AAC valve is built-in) from engine. The IACV-AAC valve harness connector should remain connected.
5) Turn ignition switch ON and OFF, and verify that the IACV-AAC valve shaft smoothly moves forward and backward. If NG, replace the IACV-AAC valve.
There are other engine parts which play a role in maintaining the right idle
speed, but the IACV-AAC is the first thing to look at. Good luck!
Jul 20, 2001 | 10:01 AM
Re: IACV-AAC
auxiliary air. ... ... [snip]"
Daniel,
Thanks very much for your response. I just went out and checked the car. When I turn on the A/C, the idle dips, and then returns to around 800 rpm. Right now it seems to be fine. I then turned on the A/C, turned on the headlights on bright, turned on the wipers and radio on, put the car in Drive and held the brake down, and the idle was at 600rpm. I think that's about normal from past experience. It seems to be an intermittent problem, but from all indications, the IACV-AAC valve is functioning properly, unless it has an intermittent problem. I'll just have to keep an eye on it. Thanks again for your response.
Van
