Lower temp on auto Climate?!?
Old Aug 12, 2007 | 04:01 PM
rockfordmaxII's Avatar
I have a 95 se with the auto climate. The lowest temp it will go is 65 deg. I thought i had read somewhere that there is a way you can change it so it will go even colder? Is this possible?
Old Aug 12, 2007 | 04:23 PM
Kevlo911's Avatar
Kevlo for President
No... 65 is pretty cold anyways.
Old Aug 12, 2007 | 05:09 PM
TurTLe*'s Avatar
tho, 65 is = max coldness on a manual climate control for the maxima. Other cars have claimed to show lower i think the lowest i've ever seen a in a car was 49 but the coldness was very similar to 65 on the max.
Old Aug 14, 2007 | 04:09 PM
Robdogg13's Avatar
Does anyone now how to change a manuel climate control to an automatic
Is it possible to change the manuel climate control in a 95 max to a auto climate control and how would you do it? Thanks
Old Aug 16, 2007 | 09:12 PM
Maximas's Avatar
2DA MAXX
Yes, this is possible. Although this was a lengthy job I did get it to work.
I found an older thread with steps in splicing into your existing wires, but I believed this to be wrong since all the tags for the ac components were mislabeled and the instructions were meant for another nissan car.
I swapped out the MAIN wiring harness located directly under the dash from a 96 max with auto-climate control and installed it into my 96 max SE with manual ac.
You do not want to use a wiring harness from 97-99 to go into a 95-96. the powering is different.
My ac works perfect!
Turbonut
46
Oct 21, 2015 08:28 PM
msellas
Sep 23, 2015 09:16 PM
bumpypickle
Sep 20, 2015 08:22 AM
