help=wheel spacers
Old Aug 15, 2007 | 06:15 AM
  #41
Snypa's Avatar
Originally Posted by NmexMAX
15mm in the rear, 5-10mm up front. Much less than spending a lot of new wheels/tires. Couple that with the fact that well, in order for these cars to be flush up front and in the rear without being staggered this is what needs to be done
ok,koool 15 in back 10 in front, and i beleive you guys, the maxima tires kinda look slaunt, so it really looks impossibly to get a good complete flush.But how far will 15back 10 front push them.?
Old Aug 15, 2007 | 06:17 AM
  #42
Snypa's Avatar
Originally Posted by Fast1one
He has two sets of wheels, I was saying sell one set and spend a little cash and getting it done PROPERLY, spacers are not the proper way for good fitment, they work well for us Max guys who have the retarded offset hub in the rear, but its always better to just do it right the first time...Or in the case the second...
There are plenty of cheap alternatives out there, Even if he broke even with wheels compared to spacers, he would still be winning. Much rather have a nice wide wheel and tire flush with the front with no need of spacer in the front...
Could just be me, being an s-chassis owner in the past, big wide wheels and flushness just comes natural to me
Edit: There was a famous (well not really) phrase that carried itself around s13/s14 forums for a while....Don't make the wheel fit the car, make the car fit the wheel
Spacers, roll fenders, pull/flare the fenders, whatever it takes to get them to fit
this sounds even more confusing, but wth,dont sweat it.its funny how the Adr's flush, but i will figure something out.
  #43
NmexMAX's Avatar
dot dot dot ...
I have 4 sets, not including stock.
And....well, I wont say it again, but I like my wheels flush but not staggered.
I'm guessing about 15mm in the rear and 10mm in the fronts.
You don't seem to know enough about the subject, so do more research or scrap the entire idea altogether.
Old Aug 15, 2007 | 06:21 AM
  #44
Snypa's Avatar
thanx alot man.!!!
Old Aug 15, 2007 | 08:27 AM
  #45
BLACKonBLACK98's Avatar
Former Vendor
theres not a one size fits all answer for this. diameter, width, offset are gonna affect what size you need. you had the right idea when you measured the distance from the lip to fender.
imo though you should either sell the rims you have or take the loss, because honestly doin spacers right will cost a good piece of what those rims did.
Old Aug 15, 2007 | 09:07 AM
  #46
Fast1one's Avatar
How can you suggest 10 in the front and 15 in the back? The rear is 15mm deeper then the front atleast from what I have measured....
Old Aug 15, 2007 | 09:45 AM
  #47
NmexMAX's Avatar
dot dot dot ...
I stated 5-10. Personally, I have 5 in front and 15 in rear. .
I need tor recenter my beam though.
  #48
Snypa's Avatar
i guess its not that easy as wel all think, cause i know i measured 30mm in the back, and there aint no way im buying those spacers for that amount,so......to hell with them spacers.
Old Aug 15, 2007 | 09:49 AM
  #49
NmexMAX's Avatar
dot dot dot ...
With that said, I vote -->
Old Aug 15, 2007 | 10:23 AM
  #50
Fast1one's Avatar
Fair enough, personally with those wheels I would go 10 in the front and 20-25 in the rear, but I think the OP finally got overwhelmed
Old Aug 15, 2007 | 11:40 AM
  #51
hacim105's Avatar
ok,i have on Ion Alloy which are 18's,dont know the offset.It so happened that i wanted my wheels to flush, but after hearing/seeing the price for spacers, might as well just wait and get wider tires with my adr rims.
Here's the thing, you getting wider tires is not going to bring your wheel out any farther than it is. Which why I still wonder why you keep focusing on the tires. Keep your tires, measure the gap and probably subtract 5-10 mm to give you sufficient clearance and be done with it. So if you measured 25 mm I'd say subtract the 10 to be on the safe side, so get 15mm spacers. Same process for the back/front wheels.
Old Aug 15, 2007 | 01:09 PM
  #52
Snypa's Avatar
that does sound like a good plan,but.........at the prices of wheel spacers,i might as well sell these rims and just get new ones sometime soon.However, if i happen to get the correct size spacers for a good price, might go with them.This thread can be closed now.
Old Aug 15, 2007 | 01:15 PM
  #53
NmexMAX's Avatar
dot dot dot ...
Try deleting your 1st post.
Old Aug 15, 2007 | 04:01 PM
  #54
Snypa's Avatar
what is that gonna do?
Old Aug 15, 2007 | 04:04 PM
  #55
Former Vendor
kill thread
Old Aug 15, 2007 | 06:17 PM
  #56
Snypa's Avatar
Originally Posted by BLACKonBLACK98
kill thread
ok,kool,learned sumin
Fbana41
Aug 29, 2016 12:18 PM
Andy29
Sep 29, 2015 05:32 AM
Lowered_a33
Sep 10, 2015 09:41 PM
dcam0326
Sep 8, 2015 11:02 PM
Maxboy23
Sep 4, 2015 06:04 PM
