I installed a CAI today and I have a feeling the filter is going to fall out
Old Aug 15, 2007 | 05:26 PM
WhiteA32's Avatar
Does anybody have the same feeling?
Like for example when I installed the stillen lip I thought it was going to fall off when I was driving on the highway....
Maybe its just me..
Old Aug 15, 2007 | 05:31 PM
andrei3333's Avatar
placebo, or bad fitment. does it move when u try with your hand ?
Old Aug 15, 2007 | 05:32 PM
67whitegoat's Avatar
If it is tight and right, no worries.
Old Aug 15, 2007 | 05:33 PM
matty's Avatar
Tighten it on there, and youll be ok....
-matt
Old Aug 15, 2007 | 05:36 PM
sports8705's Avatar
why do u feel that the filter is goin to fall off?? as long as u tightened the clamp down tight enough there shud b no problem... i installed mine close to a year ago and i've never had any problems with it.... i also installed some rubber tubing (3/4" hose cut in half to fit along the metal) along the inside of the hole in the fender to keep the pipe snug and from banging around.... that might help as well.
Old Aug 15, 2007 | 05:38 PM
WhiteA32's Avatar
Yeah I gave it a few good jiggles and it didn't fall off.... Oh well, if it falls of I will heard rattleing I'm assuming...
Old Aug 15, 2007 | 05:51 PM
Tmcgradyfann1's Avatar
close but no cigar
I as well installed one today and have a couple of questions. this is a k2 motor one purchased off ebay.. sound is great
1) the red aarow pointing to the black circle the intake cuffs came larger and where the throttle body is the round hole that connects to your MAF is smaller then what they give you. all i did was tighten the thing up really tight and i hope that works? would there be any problems?
2) The green aarow is supposed to be pointing to the idle screw or i hope so.. the idle screw is a black screw that is near where i put that aarow, the only black screw coming up. Am i correct?
3) The blue circle is where i connected the filter and the MAF sensors plastic cracked when i was tightening the bolts but it is still held on.. is this a serious thing or will it be okay?
sorry for the crappy pictures and my lack of knowledge but thats all i have to say
Old Aug 15, 2007 | 06:03 PM
WhiteA32's Avatar
Hmmmm I didn't install the midpipe... Midpipe FTL... And Mine is a cold air intake not a short ram
Old Aug 15, 2007 | 06:06 PM
close but no cigar
haha true but i thought this was the place to post this question instead of making a new thread... but what did you do with all the rubber pipes that plug into the midpipe?
Old Aug 15, 2007 | 06:09 PM
WhiteA32's Avatar
Left them plugged the midpipe
Old Aug 15, 2007 | 06:16 PM
Snypa's Avatar
try shaking it hard with ur hand, if that doesnt move it much,u shud be safe and sound.
Old Aug 16, 2007 | 06:12 AM
JtzMax's Avatar
Whatchyou say?
Ha ... I know this feeling, but only cause it has happend to me. My intake (dunno if it's a truely CAI, but it does suck cooler air due to placement) sits below my tranny and sortta off to the side. Anyway ... it sits down about 2" or so below the car (so I get cooler air) and when I park up against a parking curb ... gotta be careful no to knock it off. Done that two or three times. FTL!!!
Like mentioned, if you move it with your hand and it seems ok, it's not going to get that much jittering while you're driving, you should have it somewhat mounted.
Old Aug 16, 2007 | 06:22 AM
udienow's Avatar
My filter points down in the fender (cai) and is only held up by a clamp. I dont have the plastic fender cover, to allow air to easily access the fender... ive had it like this for like a year, fitler has never fell off. As long as the clamps and screws are tight, u have nothing to worry about.
Old Aug 16, 2007 | 07:37 AM
Neo Raven456's Avatar
I just added a hose clamp to dispel my worries, I have since taken it off and all has been well for quite some time
Old Aug 16, 2007 | 08:21 AM
chillin014's Avatar
who installed a filter without a hose clamp?.........
and I would advise putting the plastic inner-fender splashgaurd in there so your air filter isnt exposed to everything getting thrown off your tire....
Old Aug 16, 2007 | 09:31 AM
My wheel well liner fell off like he was talking about and my filter is dirtier than sin, I've since replaced the liner and am replacing the filter tomorrow.
My filter has no hose clamp on it, I might add one, but its a tight fit and I have no real fears of it falling off. But does anyone know where I can get a gasket to fit inside the hole where the CAI tube goes into the fender?
I bought my PR CAI kit used so it didn't have it, and I just macgyvered a plastic tube lining with rtv sealant, but I would like one that would fit the 3" hole (or 2.5"? i forget)
Old Aug 16, 2007 | 10:04 AM
G4nismo's Avatar
what if you hit a couple bumps and the filter wiggles off? i would play it safe and add the clamp.
whitea32, are you running the stock midpipe or the aftermarket one?
Old Aug 16, 2007 | 10:19 AM
I might put one back on, such a pain tightening it in that space though without removing the liner. its been going a good 3-4 months of driving without falling off, and a good month without the wheel well liner. even driving through some bumpy roads. but your right I probably should just play it safe
Old Aug 16, 2007 | 10:42 AM
chillin014's Avatar
Yeah man just put the clamp haha. If you put the clamp on where the tightening screw is facing the right direction you can just take a few clips off the liner and stick your arm through there and get to it.
As far as the liner around the hole, I had some rubber strip that came with my pr cai but I had to cut it because there's a metal brace or frame square tube that comes flush up under the sheet metal on the edge of the hole I cut. It prevents me from putting that rubber protector all the way around the circle. Maybe I drilled my hole a little bit too far towards the rear. Scratches up my powdercoated tube mayn.
Old Aug 16, 2007 | 11:21 AM
G4nismo's Avatar
you don't neccesarily have to remove the liner. if you have a small hand, go through the side marker hole and screw it in while supporting the filter throught the fog light hole.
Old Aug 16, 2007 | 11:27 AM
But then I'd have to remove the fog light and I wouldn't have any visibility to aim and tighten. I'll just yank the liner, no biggie.
but I still need to work out a solution for the gasket in the fender, my powder coat is all f'd too
Old Aug 16, 2007 | 11:51 AM
G4nismo's Avatar
oh, sucks for you, i have a gxe... actualy wished i had an se.
who cares if it f's up your coat. it'll f it up where no one will be able to see it.
i don't have one, well mines chrome anyways so it wouldn't matter, but it does make that clunking noise whenever i go over a bump so i made squeeze something in there.
Old Aug 16, 2007 | 12:03 PM
Yeah I don't have the problem anymore but my fix is only temporary. Even if no one sees it, i still know its there, I mod my car for myself, not others
Old Aug 16, 2007 | 02:38 PM
OnEBadAsSi30's Avatar
I switched all my clamps to Torque Series clamps made for semi truck radiators. I had my intake fall off to many times already past the maf Hasn't fallen off since.
Old Aug 16, 2007 | 07:04 PM
WhiteA32's Avatar
For the hole I used the thing that you use to cover the power wire for an amp like the black hose with a slit in it or something.
I am using the stock midpipe.
And I am using the clamp that came with it to hold the filter up
Old Aug 18, 2007 | 11:19 PM
maxpeed96plat.'s Avatar
WhiteA32, did you have to modify the hole after using the template or was it a perfect fit, reason i'm asking is... considering we're using a fleabay intake I'm not exactly sure it's an exact replica of the PR intake and I don't want to drill a mess of holes in my engine bay, my bay looks good now and I wanna keep it that way...thanks
Also, was it looming that u used? Vibration being an issue, I was thinking of using a rubber grommet if I can find one that's 3 inches.
Old Aug 19, 2007 | 07:30 PM
WhiteA32's Avatar
Well really you don't even need that template. I mounted the intake and looked where I should cut the hole. And then I cut the hole there.
Old Aug 19, 2007 | 07:50 PM
He's right and I actually believe that the template your given i a bit too far forward, causes the coupling on the throttle body to not it flush all the way around
Old Aug 19, 2007 | 07:52 PM
EnervinE's Avatar
i has college
That template was worthless. It placed the hole about 3" too far toward the front. If you're using the stock midpipe (like you should), it has some wiggle room, so just eyeball the hole.
Old Aug 19, 2007 | 10:57 PM
WhiteA32, Neo and EnervinE--> thanks for the input...will eyeball it.
Old Aug 20, 2007 | 08:27 AM
Why should we be using the stock midpipe? I'm using the one that came with it atm.
Old Aug 20, 2007 | 09:04 AM
maximafrenzy's Avatar
Fuhget About It.....
I wondered about my filter being secure too, until this year when I removed it to clean and oil it. It was on there pretty good, I guess the heat makes the rubber on the cone seal up to the pipe, I actually wrestled with it a bit to get it off.
Old Aug 20, 2007 | 11:46 AM
m00njal's Avatar
^^ Funny sig man, hah
Old Aug 20, 2007 | 04:39 PM
NiZmO97's Avatar
wow. tighten it
lowpost99
22
Sep 2, 2015 04:38 PM
Economic_Rage
Aug 20, 2015 08:27 AM
MaximaDrvr
Aug 19, 2015 08:20 PM
Trin1j23
Aug 12, 2015 08:31 PM
kirkhilles
Aug 8, 2015 10:53 AM
