Suggestions or ideas????
Old Aug 16, 2007 | 07:20 AM
MaxFanatik's Avatar
here it goes......
i had to put steelies on because i cracked one rim. Anyway my rear wheels had 1 msising lug nut on both sides. One side is fine but the passenger rear when i was taking of the wheel it was a ***** and when i was putting on the steelie, it would not sit perfectly into that circleish hub looking thing in the middle (sorry for the lack fo technical terms). so when i tightned it up, like the lower lugs would be tighten farther and closer to the wheel hub (i tried not to tighent to hard like tighten the bottom to the pt it gets bit hard than the top then the bottom and so on to get as close of equal tightening as possible).... but there is still a differce in millimeters but when im drving, it looks like my rear wheel is about to fall of, it looks like its wobbling its doing the 8 formation. Is there a way to that that center piece of????? i think it became disformed becuase one lug nut not there to hold up the weight there and the heavy 18's pressing on one side hard.........
SOOO do i need to get a new wheel hub because i kno the way im drivng its not safe, even though the nuts are on tight.
Old Aug 16, 2007 | 10:11 AM
MaxFanatik's Avatar
does any body kno if i can take that oval piece of, thats rite between the lugnuts that goes into ur wheel.
Old Aug 16, 2007 | 11:28 AM
67whitegoat's Avatar
The lug nuts do not hold the weight, the hub does. So, missing one lug nut should not cause your wheel to wobble. When you removed your 18", did you leave behind the hub ring?
Old Aug 16, 2007 | 11:35 AM
They are usually color coded. They should come off with the wheel, but sometimes stick to the hub. If it did than your OE will not seat correctly.
Old Aug 16, 2007 | 12:27 PM
MaxFanatik's Avatar
My OE wheel doenst sit on it rite now..............the hub doesnt fit thru the middle of the wheel.....
it didnt wobble on my 18's and nots not wobbling now it looks like its woblling when im driving, due to the fact tha one area of the wheel is prseed closer and tighter to the hub then the area opposite of it.
Is there anyway i can take the middle peace of and replace it or not have one?
bike4miles's Avatar
Yea, sounds like the ring of metal should not be there to me. The wheel should bolt directly onto the brake rotor. Sounds to me like there is something in between.
Old Aug 16, 2007 | 12:30 PM
MaxFanatik's Avatar
the other side is fine, same the middle of the steelie fits on that circular nub perfectly, the other side doesnt as if it is disformed and not perfectly round to go around the middle of wheel.
Old Aug 16, 2007 | 12:40 PM
bike4miles's Avatar
Ok, I'm trying to remeber what the hub looks like.. Does it look like it needs to be filed down to fit inside the wheel?
Old Aug 16, 2007 | 01:04 PM
MaxFanatik's Avatar
either the steelie holes needs to be bigger or the nub looking thinks needs ot be filed down.
Old Aug 16, 2007 | 01:19 PM
ThurzNite's Avatar
i have no idea what's going on here. Can somebody post a pic?
Jae
Old Aug 16, 2007 | 01:20 PM
96DentKING's Avatar
100 percent you left your hub ring for the 18's on the hub when you switched to your steelies. If you dont know what that is or looks like its usually a black circle piece of plastic that is meant to be put on the inside of aftermarket rims where it meets the hub. Stupid me, I was working quickly and didn't give any thought to the hub ring and did the same thing when I switched back to my stock wheels. My wheel was wobbling like a b!tch. You are most likely going to need a new hub ring and some new studs after all is said and done. A minor but costly mistake that I found out the hard way. (Maxfanatik, turn your rims around and look in the rim, you'll see what im talking about concerning the black plastic ring. Most of the time they'll stay on the rim when you take them off the car but occasionally they do get stuck on the hub.)
maximized98's Avatar
Addicted to the Org
Can you post some pics?
Old Aug 16, 2007 | 01:29 PM
MaxFanatik's Avatar
ya ill get some pics and no i didnt leave the ring on
there nothing on the nub loking piece. i will post a picture when i get home.
Old Aug 16, 2007 | 01:54 PM
Are the wheels "your" stock Maxima wheels?
Old Aug 16, 2007 | 02:01 PM
MaxFanatik's Avatar
nope, but i tried putting hte 18"back on it doesnt fit rite either, nor do the other steelies......
here some pix taken from my camera phone
Good one:
now look at the bad ones:
u can see the gap around the nub....
last pic u can see the nub sticks out alot less than it should.
Old Aug 16, 2007 | 02:05 PM
Was the RR rim the one that was cracked? If so what happen to it? If it was an impact, the hub may be damaged.
Old Aug 16, 2007 | 02:08 PM
MaxFanatik's Avatar
nope it wasnt
Old Aug 16, 2007 | 02:09 PM
MaxFanatik's Avatar
is there anyway i can get that middle piece taken out or i need a new hub ={
Old Aug 16, 2007 | 03:15 PM
The rim rides on the hub. The middle piece is just a dust cover.
Old Aug 16, 2007 | 03:17 PM
Is that a temporary spare?
Old Aug 16, 2007 | 03:39 PM
Take pictures of the bad side with the rim off.
Old Aug 16, 2007 | 04:07 PM
MaxFanatik's Avatar
its my winter wheels, and the hub looks like the other one with the wheel of u cant see a differnce....
Old Aug 16, 2007 | 05:20 PM
orudie's Avatar
Nice pictures man, but put some more
Old Aug 16, 2007 | 05:51 PM
Swap the wheels.
Old Aug 16, 2007 | 06:00 PM
MaxFanatik's Avatar
none of the wheels fit
Old Aug 16, 2007 | 06:10 PM
MacGarnicle's Avatar
why do you have 5 sockets on there...
Old Aug 16, 2007 | 06:34 PM
MaxFanatik's Avatar
LMAO....they r not sockets lol those r lug nuts
they look better on my 18's than steelies
Old Aug 16, 2007 | 11:29 PM
darklegend06's Avatar
there just lug nuts..
There made to fit aftermarket wheels because our stock ones won't fit in the aftermarket bolt hole.
Old Aug 17, 2007 | 08:33 AM
Snypa's Avatar
i dont think the entire hub is damaged
Old Aug 17, 2007 | 08:37 AM
MaxFanatik's Avatar
i hope not, is there a way to just replace the center piece?
user 11122324
42
Jul 18, 2022 03:35 PM
gavin68
Sep 18, 2021 12:36 PM
DC_Juggernaut
Sep 28, 2015 04:07 PM
Pied
Sep 26, 2015 03:29 PM
