Is my starter the problem? (video inside)
Old Aug 18, 2007 | 03:38 PM
Iron Scimitar's Avatar
Tha Snatcher
http://youtube.com/watch?v=gHZ9VIEU4Bo
You folks think its my starter? My electronics are all functioning, but my car barely kicks over.
Old Aug 18, 2007 | 05:10 PM
moogotzskillz2's Avatar
have u tested your battery??
COuld be your starter going out.. also..
Old Aug 18, 2007 | 05:11 PM
Tha Snatcher
The battery isn't even a year old. I have an Optima Yellow.
Old Aug 18, 2007 | 05:31 PM
nitromax's Avatar
sounds very much like there's a bad spot in the starter ..that little hiccup just b4 the start. yes, I'd say time for a new starter. also, if you can, check your voltage while cranking...should stay above 10 volts. if below that check the battery & connections.
Old Aug 18, 2007 | 05:38 PM
kassim503's Avatar
Try replacing the starter, when you have the starter out spin the engine by a wrench on the crank pulley and see if there is any chips or missing teeth on the flywheel.
It sounds more like a bad flywheel, but it can also very well by a bad starter, even though you might not hear gears grinding, its also worth a shot looking at.
Have you ever started your car twice? like start the car then grind the starter?
Old Aug 18, 2007 | 06:18 PM
Tha Snatcher
I started the car twice and the sound is similar. I even started the car this AM and the starter didn't make ANY sounds. I'll get a new starter tomorrow. Thanks folks.
dcam0326
Sep 18, 2015 04:52 PM
rnb754
Sep 14, 2015 11:39 PM
bennuss
Sep 11, 2015 05:55 AM
jwright36
Sep 8, 2015 11:45 AM
