poor gas mileage?
Old Aug 19, 2007 | 05:27 AM
blimblam's Avatar
poor gas mileage?
i get about 250 miles per tank. anything to better my fuel economy?
Old Aug 19, 2007 | 06:11 AM
JwaxMax99's Avatar
There is a section dedicated to your question in the STICKIES, check it out.
Old Aug 19, 2007 | 08:03 AM
Snypa's Avatar
this aint your section, but 250 is kinda bad for one tnk, i get 256 with half tank.
Old Aug 19, 2007 | 08:16 AM
EnervinE's Avatar
i has college
Fuel filter. Air filter. Spark plugs. O2 sensors. Quit being a leadfoot. etc.
Old Aug 19, 2007 | 09:38 AM
andrei3333's Avatar
quit being a big foot, oops i mean lead foot!!!
clean the TB and IACV for good measure
air filter
fuel filter (heard it doesnt affect mpg but just do it)
plugs
check for the ghost KS code (assuming u have no other codes what so ever)
make ur car light, throw the subs out of the trunk if u have any, stop picking up fat chicks thats a no no.
tire pressure
cut down use of AC
use 91 gas
do longer trips instead of turning the car on and off frequently
stop idling for no reason
make sure tranny fluid is fresh so that it shifts better and u drive in higher gears to lower RPM
smooth out the throttle, dont jab it on red lights
make sure calipers not sticking
put an insane wing on the car to create some downforce and gain 23645 mpg (not)
my maxi averages 23 mpg right now on shell v power (bone stock almost all city)
Old Aug 19, 2007 | 07:07 PM
blimblam's Avatar
my air filter and spark plugs are new. i had a feeling it would be the fuel filter and im not a leadfoot.
Old Aug 19, 2007 | 09:07 PM
vuiskool's Avatar
lucky. whoever gets 250 for half a tank, i envy you. i get 250 on 3/4s of a tanks use.
but this maxipad is just my ride for this summer, till that gs430 comes to me!. =)
Old Aug 19, 2007 | 10:09 PM
andrei3333's Avatar
dont forget that on these cars the gas guage goes down real fast from the half to the 1/4 full mark, so getting 250 Mi on a half tank doesnt mean u get 500 on a full tank...
Old Aug 20, 2007 | 04:42 PM
NiZmO97's Avatar
tune it up
Old Aug 24, 2007 | 09:29 AM
ROCKART's Avatar
wants an I35
fuel injector cleaner and tire pressure added about 50 mpg to my tank.
i just bought this car about two weeks ago - i havent got around to the plugs or sensors yet, but im sure that will help as well. with 4th gen maximas tho the plugs come with a platinum tip so they tend to last a lot longer than an average set.
Old Aug 25, 2007 | 08:06 PM
edlab03's Avatar
check all that has been mentioned above.
i get a consistant 26-27(440-450 miles) mpg mostly highway running shell vpower 93 so 250 miles to a tank is pretty bad.
Old Aug 25, 2007 | 09:44 PM
DragonMaxima's Avatar
Don't expect much of a change if you do alot of city driving. If you do mostly highway and your getting 250 then you need a tuneup.
Old Aug 26, 2007 | 12:17 AM
max ride 41's Avatar
dude, its old and you need to anty up and do a few things. clean the maf, crc on the whole housing and hot wires, air filter, plugs, ks is a possibility cause i'm only getting 300 or less to the tank full and i've had that code since i bought the car, bg fuel system and engine treatment, ( can be bought at dealer for 8.00 ) and go with no less than 89 or higher cause the 87 is $hit. and jack rabbit starts at the light will munch the gas up pretty fast as previously stated. >>>> good luck and ease up on her, a little tlc goes a long way!!!!
Old Aug 26, 2007 | 12:29 AM
SVI30's Avatar
From SJ to LA is about 360 miles and I can make it on one tank. In the city, it gets about 21mpg with my style of driving.
I think going 91 octane should help highway driving but I am not sure it helps much in the city. When the KS senses pinging, ECU enrich the fuel mixture amongst other actions and screws up the gas mileage.
mclasser
22
Nov 12, 2020 01:58 PM
maxinout93
Oct 31, 2015 02:04 AM
ef9
Oct 4, 2015 08:43 AM
