loose/noisy strut
loose/noisy strut
I have been hearing this klunk like noise coming from the front passenger side when going over a bump (of any size). i looked under the hood and noticed that the top of the strut is not moving with the vehicle. the nut on top of the strut won't tighten down. the whole thing turns instead. what is broken? is it the insulator or the bearing or what? does anyone have a better diagram than the nissan parts breakdown (aka what the dealer and courtesyparts.com have).
Originally Posted by crazyrodent
so do i need the whole insulator assembly or a few select parts?
do you have a part number? (95 gxe)
i upgraded the shocks (kyb) a while back and they are fine.
http://www.courtesyparts.com/betasit...a32b_401-2.gif
so do i need to get the 6 parts that are on the right side (starting at 54329N)?
1. Insulator -- 54320-40U02
2. Bearing -- 54325-5V000
3. Spacer-Front Strut Insulator 54329-39U00, depends how bad your spacer is.
If the boot and the spring seat is in good shape, you may leave them. This part numbers from above are for my 95 SE M/T Maxima. Check stickies also.
MaxLvr21
Oct 17, 2015 12:11 PM
maxima-junky
Oct 7, 2015 06:13 PM
JakeOfAllTrades
Sep 30, 2015 03:16 PM
