help, car dies when warm
Old Aug 31, 2007 | 12:10 PM
bearded's Avatar
'95, 165k miles, 5spd
car keeps dying right around five minutes after starting it up. problem occurs when idling at a stop light or when I take it out of gear. starting car back up is then difficult, taking around 5 turns of the key.
cel comes on but I can't pull the code because it goes off after I turn the key off then back on
help please!
edit: and oddly enough, problem only occurs once per trip and always at the same light near my house heh
Old Aug 31, 2007 | 12:35 PM
STILLENGLE's Avatar
might want to check your MAF. or IACV
Old Aug 31, 2007 | 12:37 PM
Slickismax's Avatar
Does it idle okay when it is running?
Old Aug 31, 2007 | 12:43 PM
Divewjason's Avatar
You drive that car when it cuts off at a stoplight?
Old Aug 31, 2007 | 12:53 PM
STILLENGLE's Avatar
well if the problem just recently started today then i guess so.
Old Aug 31, 2007 | 01:11 PM
bearded's Avatar
Yes, it idles fine. However, if I start the car and let idle for five min or so it will cut off.
Old Aug 31, 2007 | 01:14 PM
STILLENGLE's Avatar
Like i said check you MAF IACV and TPS.
Old Aug 31, 2007 | 01:40 PM
M in KC's Avatar
If the CEL is lit wouldn't the ECU have captured a code regardless of whether the CEL is on when you go to pull the code(s)? Your symptoms sound vaguely similar to what mine were even though I have a '97 SE Auto with 194K mi. My fix was MAF and IATS. Mine runs like a top once again.
That being said I'm in the camp with the MAP, IAVC and TPS.
Old Aug 31, 2007 | 06:30 PM
bearded's Avatar
I went to check the voltage on the maf and the harness when I noticed that the car would not rev past 2500 rpms. This is a definite sign that the maf is bad right?
Old Aug 31, 2007 | 06:57 PM
pei's Avatar
pei
check TB valve, when ur car warm up, the valve is open or close.
Old Aug 31, 2007 | 07:35 PM
Divewjason's Avatar
Well, he never stated that the problem just started today. So
Old Aug 31, 2007 | 07:52 PM
Kevlo911's Avatar
Kevlo for President
ECTS, check the codes anyways(even if the light is off)
Old Aug 31, 2007 | 08:05 PM
pei's Avatar
pei
when car have been warm up, the TB valve (choke) should be have a little bit open, in otherwise the choke still in closed position, the engine be stop it working. please check the choke when it is warm up.
Old Aug 31, 2007 | 08:09 PM
bearded's Avatar
engrish?
10char
Old Aug 31, 2007 | 08:11 PM
bearded's Avatar
Checked voltage for connection leading to maf and all was well. Decided to clean maf and problem seems to have gone away during test drive.
Old Aug 31, 2007 | 08:14 PM
bearded's Avatar
Thanks for your wonderful contributions to my thread.
Old Aug 31, 2007 | 08:41 PM
Divewjason's Avatar
Well, I would add more but I don't know much of anything about cars, which is why I'm here besides the fact that I have a Maxima. Whenever I go up to Nissan to get my keyless entry I'll be sure to ask about the problem for you.
Oh, I know you car isn't a Dodge Caravan but this person seems to have a similar problem. I hope that this will at least give you a clue.
http://autorepair.about.com/library/a/1/bl142.htm
Heck, maybe you can find someone with a Maxima that has the same problem as you do.
Old Aug 31, 2007 | 09:33 PM
bearded's Avatar
hey I'm just messin with ya man. I think I have figured out that the maf was just dirty and cleaning it seems to have fixed the problem.
Old Aug 31, 2007 | 09:34 PM
bearded's Avatar
Thanks for the help with figuring out the problem guys!
Old Sep 1, 2007 | 03:09 AM
4DRSpeed's Avatar
Project Ruby......
That definitely sounds like the culprit.
Old Sep 1, 2007 | 04:34 AM
STILLENGLE's Avatar
correct. or it could have been a IACV. but since you established it the MAF like i said before then you should be good to go.
MikesChevelle
Nov 23, 2024 11:17 AM
Lakersallday24
Jun 16, 2019 01:35 AM
kjlouis
Nov 24, 2018 06:09 AM
Balkins
Aug 12, 2015 06:39 AM
Maxboy23
Aug 11, 2015 11:59 AM
