Clutch problemss
Old Sep 3, 2007 | 01:28 PM
asperos28's Avatar
Clutch problemss
last week the car was running perfectly, then all of a sudden the clutch had no feeling and i would have to pump it to get it in and out of gear. First thing i did was i tried adjusting the clutch..didnt do anything. So then i looked under the hood to see if there was any leaks..nothing there either. So could one of the cylinders be going bad? helppp
I have a ACT Pressure plate and clutch disc and its nothing like it should be, everyone knows how that pressure plate is...
Old Sep 3, 2007 | 02:27 PM
fulloboost's Avatar
yea it sound like a master or slave cylinder problem to me. and u said the slave cylinder is full? or no
Old Sep 3, 2007 | 02:53 PM
asperos28's Avatar
yea its to the full line
Old Sep 5, 2007 | 12:17 PM
Big EEEE's Avatar
Take your master out and test it by putting your thumb over the hose fitting. You could do this without removing the master if someone else helps you with the pedal. When mine went bad, it would not pull fluid from the reservoir when I pulled the plunger out (stuck valve inside I guess). I replaced the entire master cylinder but wish I had tried the $20 repair kit from Nissan. There is a $20 repair kit for the slave cylinder also. Keep in mind there is a second bleeder hose which can collect air and make your clutch feel less than desirable. I removed my second bleeder hose completely and plugged the brass fitting with a 3/8" (if I remember the size correctly) brass plug from Ace Hardware. You can take the brass fitting off at the top of the strut tower and take it with you to the hardware store to get a proper fitting plug. Or just bleed the second bleeder hose…but it holds a lot of fluid, takes up room, and is not needed.
user 11122324
42
Jul 18, 2022 03:35 PM
Mar 12, 2020 12:06 AM
spencerwh1
Jun 30, 2016 05:44 AM
BkGreen97
Apr 2, 2016 05:47 AM
carlosvq30
Sep 26, 2015 09:44 AM
