Problem With Auto
Old Jul 22, 2001 | 11:20 AM
MICHAELCORY's Avatar
I have a 97 Auto GLE and the auto shifter seems to be dragging or stuck at times. I have checked all fluids and all are good. What could be the problem and what do I need to do to fix it. Thanks in advance.
Old Jul 22, 2001 | 11:28 AM
Daniel B. Martin's Avatar
There are several tests you can make with the fluid on the automatic transmission dipstick.
1) Level. It should be up to the full mark. If not, add as required.
2) Color. It should be bright red and translucent. A brown or black color is a sign of fluid degraded by excessive heat, and/or worn friction materials. A milky pink "Pepto Bismol" color is a sign of water contamination.
3) Odor. It should have a clean oily smell. A burned odor is a sign of fluid degraded by excessive heat.
4) Feel. Wipe the dipstick with your fingers and then rub your fingers together. It should be smooth and slippery. A "gritty" feeling is a sign of worn friction materials.
Sometimes the service life of a transmission can be extended by changing the fluid. Automatic transmission fluid is loaded with detergents, so new fluid can clean the insides of the transmission. If you decide to do this, find a shop that uses the Magic Sucker Pump which removes -all- of the old fluid. An ordinary drain-and-refill changes only about half of the fluid.
DJLAX152
May 4, 2021 11:46 AM
Mar 12, 2020 12:06 AM
slowlifer
Sep 8, 2015 05:53 AM
