changing clutch
Old Sep 6, 2007 | 05:24 PM
Maximeltman's Avatar
changing clutch
my clutch is slipping. I have a leaking driver side axle and I'm not sure if that's what is causing my clutch to slip, I don't think that it would, right? I have about 76k on the stock clutch right now, is it just time to replace it? Any help will be greatly appreciated.
Also, is repairing the driver side axle seal hard or simple? When I'm under the front of the car and I spin the front wheels with my hands, the driver side axle has some wobble coming out of the transmission.
Old Sep 6, 2007 | 05:45 PM
1chewabacha1's Avatar
Read the stickies...
Motorvate.com
Bad axles does not cause clutch to slip. bad axles = tires on that side might not be rotating.
driver side wobbles out of the tranny? Dangerous.... have you thought about the teeth of the axle or tranny? Better check it to make sure you didn't smooth those suckers down.
Old Sep 6, 2007 | 06:39 PM
dgeesaman's Avatar
Maintenance Monster
Your clutch and driver side axle are in different places. They can't possibly be related.
Grab that axle end where it enters the tranny. If you can push it up and down and make the stuff inside the tranny move with it, you have a shot transmission. Axle seal change won't help at all.
Dave
Old Sep 6, 2007 | 07:07 PM
Dave
But how can it be shot if it still drives?
Old Sep 6, 2007 | 07:13 PM
dgeesaman's Avatar
Maintenance Monster
I mean the tranny bearings are shot. It causes leakage at the axle seals, greatly increased gear wear, and much greater likelihood of shattering a gear.
I suggest you take the car to a transmission repair shop and have them do a diagnosis. With that diagnosis in hand you can decide what to do about the problem. (Many tranny shops don't do an effective job of rebuilding Maxima trannys, and they are all very expensive).
There's a whole section in the sticky faq thread about manual trannys, you should read that.
Dave
Old Sep 6, 2007 | 08:02 PM
any good clutches out there? I've read that the 5th gen OEM clutch is great for our 4th gens...what's the price for those?
Old Sep 6, 2007 | 08:05 PM
how about this one...http://cgi.ebay.com/ebaymotors/EXEDY...spagenameZWDVW
Old Sep 7, 2007 | 08:06 AM
DAVE...I pushed the axle and it move just a bit up and down, while the passenger side axle does not move at all. I cant tell if it's moving the stuff inside the tranny up and down with it because it's like 1/8" of Play. It does move in and out of the tranny about 1/2" though...any thoughts?
Old Sep 7, 2007 | 09:14 AM
dgeesaman's Avatar
Maintenance Monster
In and out 1/2" sounds like something really odd.
Are you moving the big rusty hunk of axle that's between the tranny and the inner rubber axle boot? This is the part that you should be trying to move to find tranny bearing play. It should move in/out just slightly, like less than 1/16". If it moves up/down or side/side, that indicates bearing wear in teh tranny.
The axle itself, between the two rubber boots, can move in/out by design to allow for suspension travel and steering. 1/2" sounds about right.
Dave
Old Sep 8, 2007 | 11:52 AM
I think that my differential has the worn out bearing, but just on the driver side though. Since I bought the quaife ATB diff, I'll probably use this opportunity to install that...dealership quoted me$1,000 or so. Also, are the differential bearing both the same size? the phone tech at the dealership said they are both the same size, but I always thought there was a small/big one.
Old Sep 8, 2007 | 04:03 PM
dgeesaman's Avatar
Maintenance Monster
The carrier bearings are identical on open diff models. Different on VLSDs.
I'm surprised a dealer is willing to install an aftermarket diff for you, and maybe more surprised that they'd be competent to do so.
Dave
Old Sep 10, 2007 | 06:35 AM
so if I put the quaife diff in the tranny, then the bearings would be the same size ?
Old Sep 13, 2007 | 06:25 PM
dgeesaman's Avatar
Maintenance Monster
Yes, if it's designed to fit in an open diff tranny.
If it's designed to fit in a VLSD, they will be two different sizes.
Old Sep 13, 2007 | 08:15 PM
okay thanks alot Dave. your help is much appreciated.
Old Sep 15, 2007 | 01:15 PM
btw where's a nice place to buy a clutch? preferably oem 5th gen for a descent price?
Mar 12, 2020 12:06 AM
BkGreen97
Apr 2, 2016 05:47 AM
f.matejaiii
Sep 21, 2015 12:09 PM
RWCreative
Sep 21, 2015 11:01 AM
pears
Sep 18, 2015 05:25 AM
