Need help assembling Cig Lighter into shifter trim
I just bought a new 5 speed shifter trim as well as the cig lighter piece and the ring that goes around it but I can't seem to figure out how to attach it to the shifter trim..anyone have any ideas? Or if someone can be so kind as to take a pick of theirs and how it fits? I messed w/ it yesterday and I don't know how to attach it! Thanks in advance guys!
Do I push the piece in from the front of the trim or from behind? I thought I tried it every way possible but I guess not...
Also the only pieces you need is that black plastic ring and the actual 12v adapter itself right?
ok you have the wire that looks like a "T" electical plug that plugs into the cigerettle lighter...you hold that piece with your hand and put the shifter trimer down into the console and then you have to hold that T wire through the hole and then you plug your cigerette lighter into that T plug from the outside of the shifter trim then you should do what Post #2 said
or you can just have your cigerette lighter pluged into the shifter trim doing what Post #2 said then plug the T electical plug into that Cig lighter and then just install the shifter trim into the console....
http://www.trademotion.com/partlocat...98&catalogid=2
That's the site, just call them to order it, it's much easier to call them and tell them what you need!
ok do u have the shifter trim piece out right now ?
basically it snaps in from behind so that when u use it it doesnt pop out, its got like this little plastic piece sticking out, u put it into the trim piece hole and twist, much like a screw
Step 1: have the input plug sitting outside of your shifter trim Ciggerette lighter hole(yes my shifter trim is cracked but it will still show you how to do it).
Step 2: Plug the ciggerette lighter into the plug that is sticking out of your shifter trim
Step 3: Push the whole unit through the shifter trim and rotate till it locks into place(you will be able to feel)
Step 4: Installing the shifter trim to the middle console- Push the top of the shifter trim into the console first(as shown, yes my shifter trim is cracked on the bottom but still doesnt matter)
Step 5: snap the bottom part of the shifter trim into the console by pushing down in to the console (push on the left and right bottom corner you will hear a snap, which means it is secured into the console)
Yea thats all i can help you with
atriuum
09-28-2015 01:19 PM
