clicking noise... ?
I just got new brake pads ( back and front) and I also got all the rotors resurfaced at an independent shop. Now, I'm hearing a clicking sound from the right front side... I did not hear this noise before.
Do I have to get a new rotor... or can it be something else like the cv joint? Because, I did see something leaking from the cv boot and I took it to the shop, and they told me it was just water from the a/c....
Can someone help out.. Thanks...
DBM?
DBM?
DBM?
DBM?
More information please
DBM?
DBM?
DBM?
DBM?
- bad Constant Velocity joint
- bad r/f wheel bearing
- bad drive axle support bearing
- loose drive axle support bearing bracket
- cracked rotor
- defective accessory drive belt
- defective accessory drive belt tensioner/idler
Re: More information please
Originally posted by Daniel B. Martin
Do you hear this sound when your foot is on the brake, off the brake, or both? Is the sound more pronounced when you are turning in one particular direction? Is it one isolated click, or a series of clicks? If a series, are the clicks rhythmic or random? If rhythmic, is the frequency related to engine speed, vehicle speed, or neither?
Possible causes of this symptom include...
- cracked rotor
- cracked rotor
Thanks.
DBM, can you tell me some reliable places to go in order to diagnose this problem correctly because the places I went to were not helpful at all...
Ask friends, neighbors, coworkers. Chances are you will hear some horror stories, and also some glowing recommendations.
Independents usually charge less than the dealer. Perhaps you will find a former Nissan dealer technician who opened his own repair shop. That's a good man to know!
jmlee44
10-02-2022 02:13 PM
