Are KYB GR-2s any good????
Old Jul 25, 2001 | 11:25 PM
BriGuyMax's Avatar
I haven't seen a lot about them on these forums....the Koni's are a bit out of my price range, and I haven't heard too much good stuff about the Tokicos. I also have NO clue what springs to get. I want a good drop....my friend Josh (Maxdriver847) has eibachs/Tokicos...and I really think they could be a little lower...would I be dumb to go with sprint springs or apex??
Old Jul 25, 2001 | 11:39 PM
vmok's Avatar
I don't have them on my 4th gen but I have them on my 3rd gen fronts. Also had them on a Chrysler a while back. They're quite stiff (they use a high pressure gas charge) and seem to work pretty good. However, all the applications that I've used them for have been stock height stock spring vehicles.
They're good if you're looking for an aggressive ride (sometimes slightly harsh) as they're stiff. Should be able to control stiffer springs fine.
-V
Old Jul 26, 2001 | 03:59 AM
fnkmaster's Avatar
i have pretty much the setup ur thinking about. the apexs drop the car by about 1.6". and its combo with the gr2 is really good. ride is not very stiff, but u will feel a lot of the road! like i said before, i think this combo is just right. if ur coming to maxus, u could prolly check it out there. peace.
Old Jul 26, 2001 | 06:24 AM
mzmtg's Avatar
Minister of Silly Walks
I'm starting to not like my Tokicos. How is the rebound damping with the KYB's? With the Toks, when you hit a big bump, the car bounces up off the bump, instead of just soaking it up. Do the GR-2s do that, or do they keep the car down and controlled over bumps?
Thanks.
Old Jul 26, 2001 | 06:55 AM
fnkmaster's Avatar
Thanks.
from my experience with them, they pretty much make sure my car doesnt fly off the road. also since i started using them i know that unless i do about 100 mph on a bump, the car will stay glued to the road. only drawback for me is that i have the 16" rims... bigger tires and forget it... the car is not going anywhere! u will still be in control of the car and no fish tailing or nothing when going over bumps. i'd definitely recommend the gr-2's to anyone who may be interested.
Old Jul 26, 2001 | 07:05 AM
_DRU_'s Avatar
kyb's... how much are they going for and where can i find them at? thanks
Old Jul 26, 2001 | 07:07 AM
mzmtg's Avatar
Get a quote from shox.com
riggy's Avatar
think custommaxima has a deal going right now. not sure. just check. later.
Old Jul 26, 2001 | 07:32 AM
fnkmaster's Avatar
if ur in canada, go to jrp... i know the guy pretty well and he cut me a very good deal. saved on shipping, and got my gst back at the border! i'm looking for my reciept right now, i'll post the price i got it for later.
Old Jul 26, 2001 | 08:05 AM
got rice?'s Avatar
I have them at $260/set for the 4th gen. Email me if you're interested.
They are going to ride similar to stock.
Old Jul 26, 2001 | 08:36 AM
_DRU_'s Avatar
do you know if they will go well is Sprint springs? and is that $260 shipped? thanks
Old Jul 26, 2001 | 09:48 AM
Azeem's Avatar
I have the KYB GR-2's with my Eibach springs. They are very good. A bit stiff, definitly stiffer then stock, but handling is up quite bit
Old Jul 26, 2001 | 11:07 AM
shadygrey's Avatar
I posted on this topic before
I have the H&R/KYB setup..
Here's the thread:
http://forums.maxima.org/showthread....threadid=42964
Old Jul 26, 2001 | 12:22 PM
got rice?'s Avatar
No, shipping is extra (around $15). I don't know anything about the Sprint springs (ie spring rate) so I can't make any recommendations.
Old Jul 27, 2001 | 03:13 AM
BluethingSE's Avatar
I just had H&R's and KYB GR-2's installed a few weeks ago. I'm really satified with it. It rides better than it did before (my struts were dead though so it was pretty rough). The combo soaks up small bumps pretty well but of course large bumps and potholes are rough and tough, but they were before too. I got the KYB's for $259 at www.shox.com.
Old Jul 27, 2001 | 01:39 PM
got rice?'s Avatar
Damn, I'm $1 more expensive at $260/set LOL
Old Jul 27, 2001 | 02:39 PM
Man, if I'd known that Phuong, I would have gotten them from you just to show some .org love...
Old Jul 27, 2001 | 03:01 PM
SillePimp's Avatar
Thanks.
Sounds like the same problem I have. I've had my Eibach/Tokico setup for almost two years now. I can tolerate the ride during normal driving but when I encounter bumps on freeway constructions, it makes me think more about getting something else. But heh, it comes with a lifetime warranty!
Old Jul 27, 2001 | 09:07 PM
RedMax95's Avatar
do the KYBs require modification on install like the konis? if they dont then kyb is the way for me
Old Jul 27, 2001 | 11:07 PM
Nealoc187's Avatar
SLOW
I have KYBs with Ground Control coilovers. They are matched pretty well to my spring rate, but a tiny bit underdamped on rebound. Remember however that the GC springs are basically the stiffest springs you can get for the maxima (you can get any rate you want, I got 450 from 325 rear). They require a little bit of grinding if you are going to use GC coilover sleeves with them, literally took me about 5 minutes each in the front. The rears dont require any grinding. If you are going to be using normal lowering springs and not coilovers, they wont require any modification. I also had these on my civic, and I was happy with them then, and I am happy with them now.
Old Jul 28, 2001 | 10:57 AM
BriGuyMax's Avatar
Thanks for all the info guys....I'm am DEFINITELY getting the KYB GR-2s. I think I've also decided on Eibach springs.
Old Jul 29, 2001 | 09:47 PM
RedMax95's Avatar
i will get them when i finally put on the sprints that are sitting in my room
The Frye
Sep 2, 2021 11:03 AM
MaxLife17
Jun 27, 2019 01:37 PM
BkGreen97
Apr 2, 2016 05:47 AM
dvcamp
Sep 18, 2015 10:17 AM
MaxLife17
Sep 8, 2015 02:36 PM
