taking off HAMBURG on fron grille of 96 MAX
Old Aug 2, 2001 | 09:08 AM
ghettomaximaz's Avatar
hey guys,
i want to make my own mesh grille and i want to know hoe to take that annoying ahamburg sign off the front grille of my car, is there a screw thats holding it in, is there an easy way to get it off???
thanks
Old Aug 2, 2001 | 09:55 AM
SuDZ's Avatar
Heat
Everyone who seems to take theres off recommends plenty of heat and some goo b gone or something like that type of product to lossen up then get rid of the glue that will be left behind. After doing alot of goop gone stuff try waxing it after to see if it is still noticable, if so want and try to get rid of it some more
SuDZ
Old Aug 2, 2001 | 01:32 PM
Dreizehn's Avatar
I've never seen it taken off of the front grille...
If you're putting a mesh grille in why don't you just cut out all the plastic back there... Won't you see it behind the grille????
Old Aug 2, 2001 | 01:53 PM
SmoothMax's Avatar
OG
I took mine off by simply using a flathead screw driver and prying it off. Of course I broke it in the process, but since I shaved my rear emblems as well, I just used the Nissan emblem from the rear of the car and put it over my mesh grille since you can see where you tok it off through the grille.
Does that sound right????????
Old Aug 2, 2001 | 03:04 PM
hlh0501's Avatar
screwdriver
I just took a screwdriver and verry slowly pried it off from the top and bottom... it has two posts sticking out the back, so go from both sides... it'll come right off, I didnt do ANY damage to mine, and then there is a little sticky on the grill, you can pull it off in 1 big clump w/ your finger... verry easy
matts95max
Apr 23, 2025 10:44 AM
MaxLife17
Jun 27, 2019 01:37 PM
The Frye
Feb 3, 2019 08:34 AM
MaxLife17
Sep 8, 2015 02:36 PM
Maxima30
Sep 7, 2015 06:13 PM
