Air Conditioner
Old Aug 4, 2001 | 09:08 AM
philticer
I need to recharge my air conditioner on my 95 SE, but am not sure where the connection is. Is there any information or diagrams available to show exactly where the connection is?
Old Aug 4, 2001 | 10:19 AM
Daniel B. Martin's Avatar
Please refer to the Haynes repair manual, page 3-13.
Old Aug 4, 2001 | 11:30 AM
philticer
I don't have the manual. That is why I asked the question.
Old Aug 4, 2001 | 01:48 PM
cbr2's Avatar
id be way more worried
about where my fluid went in the first place...
PS you can find the part on any car by looking at the lines that come from the condensor. I believe(not sure, car is not w/ me to check) that place on the max is on the passanger side... sorta by the shock tower.. Look for a blue cap.. unscrew it and that is where u add it
Old Aug 4, 2001 | 04:35 PM
Eric L.'s Avatar
So I suppose if I told the location, then you would know what to do?? Believe me, if you want to work on your own car, spend $20 for the Haynes or Chiltons manual.
The AC recharge line is along the passenger side of the engine bay. The recharge plug is a blue cap along a metal tube which runs from to the AC condensor.
Working on your own AC is not recommended, since there are strict environmental regulations that must be adhered to when working with AC refridgerant.
Old Aug 4, 2001 | 06:41 PM
philticer
Re: id be way more worried
Thanks. I was pretty sure that was the place. I wanted to make sure I did not get the High pressure valve. Turns out there is an "L" & "H" on the caps. I was just looking for some confirmation. I've already added it. Works great now.
I have had the problem for years. Paid a $100 to replace a hose last year to "fix it". Plus the $40-$50 to test & refill it every time. Codes require testing. I don't want to keep paying to "fix it". I got a kit for $28. I add a can of refrig annually for about $6-$8.
This works for me. Thanks again.
tarun900
19
Dec 20, 2021 06:57 PM
aw11power
Oct 10, 2021 04:57 AM
Miket2006
Mar 1, 2021 03:55 AM
Justin Kroll
Oct 1, 2015 07:03 PM
MichMaxFan
Sep 30, 2015 09:18 AM
