Lights in clear corners
What if you were to drill out a hole in the back of the corner lights and add a bright clear bulb in the housing to come on when you cut your lights on (to match the others), but when you use your blinker it switches to the regular orange light. Just wondering if anyone has done this and if so do you have a pic?
There's another idea...
I used a dual-wattage socket for the front lense so the lower-wattage comes on with the park lights and blinks at the higher-wattage when I signal. You can find dual-wattage sockets (1157 sockets) at your local Trak Auto or Autozone. To make it fit though, you have to file down one or two of the tabs. Check out my profile pics to see how they look at night.
Re: There's another idea...
Cheers
Re: Re: There's another idea...
Originally posted by zagato27
Sounds like a pretty good idea. Saw your profile pics. Can you get a bit more descriptive on how you did the deed? Will it work with the rewired corners, ie. alternating blinking between the front corner and side corner? Tell us/show us more!
Cheers
Cheers
Brighter Corners
Ok Here is the STOCK Bulb. It has Two Nips on it.
As you can see here...
What you have to do is remove the one closest to the actual bulb.
See what I mean..!
When you put it back in the outlet place it in backwards. If NOT you will have NO change in brightness. Below is the Final Product.
Your DONE..!
See what I mean..!
Your DONE..!
Re: Brighter Corners
See what I mean..!
Your DONE..!
See what I mean..!
Your DONE..!
fastcarny
Oct 6, 2015 10:42 AM
ballerchris510
Sep 10, 2015 09:35 PM
Maxima30
Sep 7, 2015 06:13 PM
JoshG
Sep 5, 2015 10:10 PM
