Steering Wheel Vibration
Old Aug 6, 2001 | 10:10 PM
camaro1698's Avatar
I own a 1998 Maxima SE and the steering wheel vibrates between 75 and 80MPh. I had six shops look at it and no one can find the problem. It's not a huge shimmy, but its annoying. I've replced the tires, rotors, pads, had an alignment done, had the tries balanced by 4 different shops and yet I still get the same shimmy. Does anybody else have this problem. The car was bought new and the problem started happening at about 10,000 miles. There is now 60,000 miles on the car. When the car was under warranty I brought it numerous times back to the dealer, but all they did was balance the tires. This never helped, but the dealership insisted that balancing was the only thing that could be wrong with it. Any ideas please post or email me. Thanks!!
Old Aug 6, 2001 | 10:15 PM
97GreenMax's Avatar
I'm having the same problem, its worse for me at about 85 mph. It doesn't doo it too bad so I have never really worried about it.
Old Aug 6, 2001 | 10:19 PM
dmbmaxima2k2's Avatar
Maxima.org Sponsor and Donating Maxima.org Member
ya i have the same problem from like 75-85 and i've had it looked at and nothing.
Old Aug 7, 2001 | 07:15 AM
Jason96GLE's Avatar
I too have this problem except my shimmy starts around 60-65 and get progressively worse as I go faster. I replaced tires, 2 4-wheel balances, 1 alignment and same problem. I checked the front end for worn suspension parts and had a mechanic look at it as well and no problems found. I'm thinking it may be the front struts cause I have 80K on the originals.
Old Aug 7, 2001 | 07:48 AM
totochilla's Avatar
same here
i just bought a 98 se and i have th same problem with 38k on it, it starts vibrating around 70 mph. im sending it to the dealer to get it checked out but sounds like no one is havving any luck.
Old Aug 7, 2001 | 07:54 AM
stash905's Avatar
I am having the same problem. My 98 Maxima with about 75,000 miles starts vibrating at about 65mph. I had 4 new tires put on, blanced and an alignment and it still vibrates. This shouldn't be. Why are so many people having the same problem?
It would be great if somebody knows a common cause.
Old Aug 11, 2001 | 03:03 PM
mo'max's Avatar
vibration
I get this everytime I take my car for wheel work (tires, rebalancing, etc). I have found that re-seating the wheel is all that is necessary. You can do that in your driveway.
I have no evidence to back this up, but it is my opinion that our cars are very sensitive to inproper seating. I believe that the problem is caused at the shop when impact wrenches are used to seat the wheels. I always ask for them to hand torque the lugs. When they do everything is fine..you know the feeling. Try to watch the mechanic as the wheel is seated. Sometimes they use the impact wrench to "start" the lug nuts and then finish it off with the torque wrench. I have found that this is not a good way to do this either.
Hope this helps.
JoshG
51
Sep 21, 2015 10:41 PM
Bonka
Sep 14, 2015 11:18 PM
2kmaximel
Sep 10, 2015 08:13 AM
SusieQQ
Sep 9, 2015 12:14 PM
coasterswim
Sep 2, 2015 07:43 AM
