y-pipe..worth it?
Old Oct 23, 2000 | 09:39 AM
ssy's Avatar
ssy
is the y-pipe worth the money? what does the butt dyno say for all of you that have it?
also, what does "for off-road use only"? will it pass emissions without the pre-cats?
I have the POP charger and stillen exhaust.
TIA!
simon
Old Oct 23, 2000 | 09:43 AM
Vic's Avatar
Vic
Yes
enough said =)
Vic
Old Oct 23, 2000 | 09:44 AM
Shingles's Avatar
The missing moderator
TIA!
simon
Butt dyno? Why bother with butt dyno with a real dyno say the combo of CAI and Y-pipe makes 20hp to the wheels?
-Shing
Old Oct 23, 2000 | 10:54 AM
ssy's Avatar
ssy
how's the installation?
Old Oct 23, 2000 | 11:50 AM
MADMAN's Avatar
how much
How much does a ss y pipe cost?
Old Oct 23, 2000 | 12:19 PM
ssy's Avatar
ssy
Re: how much
the y pipe runs about 350 for the jet hot and 450 for the stainless steel
Old Oct 23, 2000 | 12:24 PM
Supa Lao's Avatar
I didn't install mine myself, b/c I didn't want to fight w/ the rusty bolts under the car. I took mine to a shop, and they charged me $60. It is worth it!!
Old Oct 23, 2000 | 03:18 PM
Jose's Avatar
Besides a supercharger the ypipe is about ->
one of the few mods that you can actually feal the power difference. Its a must if you want to go Rustang hunting!!!
TIA!
simon
Old Oct 23, 2000 | 05:06 PM
brandonj's Avatar
I installed mine myself a couple of weeks ago. It wasn't too bad, but I did run into a couple of problems. One of the nuts on the cat was rusted completely on and I ended up stripping it, so I had to cut it off. Then, my dealer gave me the wrong size gaskets, so it didn't seal right the first time. Once I figured it out though, it only took about 15 minutes to take it off again and put it on right. I guess it was kind of a pain, but I get some kind of sick satisfaction from doing stuff myself.
Old Oct 23, 2000 | 09:09 PM
BEJAY1's Avatar
Conecarver
I was stupid and bought the Y-pipe last. Too bad the buttdyno didn't vote to buy it sooner.
Get it and some air intake at the same time!
Old Oct 23, 2000 | 10:49 PM
MisterMatt's Avatar
Will you pass emission with the y pipe??
Whats the b pipe? Whats the difference between the two?
SEE YA
Old Oct 24, 2000 | 12:23 AM
mrloyd
difference
The y pipe is the pipe used to collect the exhause gasses from the two cylinder banks, it is right under the engine and leads to the cat. The b pipe is the pipe that goes from the cat to the muff. If you get a cat back system it comes with the b pipe. I have neither, but hear the y pipe is the s t, esp if you get the rt cat to go with. Lotsa peeps get the y, the rt cat and a custom b pipe for max power, but stick with the stock muff for quiet sound. From what i hear the precats on the stock y are only for when the engine is cold, so if you warm it up it passes emissions. Hope this helps
Old Oct 24, 2000 | 01:01 AM
Vitaly O.'s Avatar
I want one
I started calling and looking around for y-pipes but the best price seems to come from stillen $290 and I heard that it fits much better than the cattman one and it is stainless steel cattman charges $450 for that one
WHATS THE CACH?
Old Oct 24, 2000 | 07:48 AM
MaxiPad96's Avatar
290 WOW well if that is the case I would like to know what is the catch as well..
Old Oct 24, 2000 | 11:57 AM
Vitaly O.'s Avatar
I dont know
When I called them 3 days ago I was surprised my self but actualy it was $299 thats still beter than anywhere else so far the guy that I talked to his name was Kenny
Old Oct 24, 2000 | 09:19 PM
BEJAY1's Avatar
Conecarver
Stillen used to have lots of problems with their 1st gen Y-pipe. I hear the new 2 piece is much better - no more "bees in a can" sound.
The big difference between Stillen and Cattman is the metal. Cattman uses Stainless Steel. Stillen uses regular steel that will rust over time
Brian Catts just closed his $400 group deal a couple weeks ago on this board. 10+ buyers jumped on in only 4 days
http://forums.maxima.org/showthread.phtml?threadid=2736
Maybe if enough people get together he'll do another deal.
P.S. My local shop hadn't seen the SS Y-pipe til now. They were very impressed with the fit and quality. Means alot coming from somebody who's done 6+ Max S/C installs!
Old Oct 24, 2000 | 10:33 PM
Vitaly O.'s Avatar
Stillen said that it is stainless stell
but my question is which one fits better stillen or cattman performance
Old Oct 24, 2000 | 10:45 PM
brandonj's Avatar
I have the Cattman Jet-hot, and I can't imagine a pipe that would fit any better.
Old Oct 24, 2000 | 11:18 PM
Vitaly O.'s Avatar
Im going crazy I cant make up my mind
AAAAAAAAAHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHhhhhhhhh hhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhh h
Old Oct 24, 2000 | 11:36 PM
Kato
Re: I want one
WHATS THE CACH?
If I'm not mistaken, the Stillen pipe is not stainless steel, but rather a nickel plated mild steel. Either way, the rep I spoke to claimed it was resistant to corrosion. Not sure if anybody has had probs with the Stillen pipe rusting on them.
Old Oct 25, 2000 | 07:37 AM
SkidMarkRacing's Avatar
Question
I also got the $299 price from stillen as well. That is for the stainless one. What is the difference between the stainless and the JetHot one. I would think that since the Jet was already coated it would be the better of the two however it cost less (from catman) what gives?
Old Oct 25, 2000 | 08:31 AM
BSwithTF's Avatar
Cattman s/s y-pipe
I read that the Jet-Hot y-pipe is about to be discontinued. I was going to get a Jet-Hot but it was backordered 2 or 3 weeks so I got the s/s one. I put it on myself and it fit perfect. Took about 45 minutes.
Old Oct 25, 2000 | 11:36 AM
ssy's Avatar
ssy
y pipe
what do you need to put the y-pipe on?
we should all get together and call stillen for a group deal on their y-pipe!
whaddya think?
Old Oct 25, 2000 | 11:57 AM
Kato
Re: y pipe
whaddya think?
Good luck with that....
Not to be pessimistic, but got rice ordered about $3000 in parts from Stillen and they wouldn't budge on a discount.
Old Oct 25, 2000 | 12:04 PM
stjohnr's Avatar
I have cattman's ss y-pipe. Fit and finish
is excellent. Noise is a non-issue as I still have the
stock intake and exhuast.
Old Oct 25, 2000 | 05:19 PM
Vitaly O.'s Avatar
so why is stillen less expensive than cattman
usualy with everything stillen is more expensive than anywhere else but with this it has the best deal whats the catch does anyone know
Old Oct 25, 2000 | 05:21 PM
96BLUMAX's Avatar
If you header wrap the stillen ypipe it shouldn't rust at all. But i have never really heard anyone complain about it before anyways.
Old Oct 25, 2000 | 09:08 PM
VQdriver's Avatar
i wanna know what this $299 deal from stillen is all about..so for that price you get a full stainless steel y-pipe? does anyone have this pipe installed on their max? how's the fit, finish, and performance? any bees in the can noises? i'm debating about the stainless versions of cattman and stillen. $299 is a big difference from $450!
Old Oct 26, 2000 | 05:22 PM
BEJAY1's Avatar
Conecarver
Jet Hot pipe is going away. Cattman SS replacing - much better seller.
Unless Stillen changed their pipe it's still "Chrome plated mild steel". Page 28 of their '99 catalog.
Old Oct 27, 2000 | 05:16 AM
PRPmax's Avatar
Hmmmm ..
So know one in here actually knows which "Y" pipe is better? ....
Also i wanted to know how much improvement does do have on my car? And if its that much of a improvement where can i puchase one.?
Also i live in Marietta, Ga so would any one know if this would effect emissions ?
Old Oct 27, 2000 | 05:54 AM
BEJAY1's Avatar
Conecarver
Either Y-pipe is an excellent investment. Advertising says 15-25 hp. I haven't run dyno's or 1/4's yet to prove.
Can say it makes more of a difference than any other N/A mods I've done. RTCat, CAI, UPD for instance.
It's something you can feel when you drive!
Old Oct 27, 2000 | 08:54 AM
Jeff92se's Avatar
I'm needing a caw
The last time I heard, Stillen's Y was NOT SS STEEL. From a pic I saw it was just chromed mild steel. Confirm before considering ordering the Stillen unit.
Old Oct 27, 2000 | 09:19 AM
Wayne
I have a question,does the y-pipe make the car louder? I still have the factor exhaust
Old Oct 27, 2000 | 10:02 AM
stjohnr's Avatar
On my 99SE with stock exhaust, it does not
Old Oct 27, 2000 | 10:18 AM
SS-Ypipe
I had the bees in a can sydrome with my Stillen, and replaced it with a Cattman and it went away.Y-pipe is the best NA HP/Tq increase you can buy I think. You really can feels the difference when you push the pedal. As far as noise goes, if you have a stock muffler the noise increase is minamal. With a b-pipe or aftermarket muffler or both, the noise is drastically louder. I think it sounds good though. My .02$
Old Oct 28, 2000 | 06:21 AM
SterlingMistMax's Avatar
No it doesnt make it louder
but you will actually hear the muffler
now
Old Oct 29, 2000 | 04:14 AM
chris j vurnis's Avatar
Y PIPE... Worth it???
To answer and comment on a few questions in this post..
Yes, it will pass emission when the car is warm... But running a Y-Pipe is completely illegal in all states since you are removing the pre-cats... Most shops will refuse to do the work due to legal liabilities...
This does make a big difference in overall smog output...
If you only had the primary cat-converter without the Y-pipes, you would probably have to drive your car for several hours after warm up to equal the smog output of your car in the first few minutes of warm-up...
I don't know how often any of you drive for hours each day... For the average driver, the total smog output will dramatically increase... I don't have exact numbers, but when you consider that the emissions components remove an extreme majority of pollutants, you can start to imagine what removing the pre-cats can do to smog output...
I would like someday to experiment with an aftermarket Y-pipe but cut-out sections to integrate the OEM pre-cats...
The pre-cat removal isn't the sole reason for HP gains... the 2-to-1 output collector and all the rest of the piping bends are less restrictive than OEM as well... Maybe would be worth a gain of 5-7HP... I think the aftermarket Y-pipes are good for about 15HP without pre-cats..
Old Oct 29, 2000 | 01:27 PM
96BLUMAX's Avatar
My car is definetly louder because when i start it i can hear the muffler because of the increased flow. Also the front of the car makes more noise because the old ypipe was covered head to foot with heat shields and crap, so the new one lets off more noise. Not to mention how it slips up the speedometer now. Its crazy. I don't even have to push my foot down that hard and it takes off. But thats with a CAI as well.
Old Oct 29, 2000 | 09:22 PM
max1ma97se's Avatar
is y pipe gonna hurt the factory cat im gonna buy a y pipe soon from stillen i dont car about stainless steel i live in cali no snow here. i like noise tht y i wanna keep stock cat
Old Nov 7, 2007 | 12:06 PM
maverick1223's Avatar
Lil' bit more than Newbie
This may be a stupid question but what's the advantage to installing a Ypipe for just a regular driver (just around the city to get groceries and do errands etc, I'm not a racer.....yet ) Better gas? Better ride? Sounds fancy? Thanks
