Indiglo Gauge Install Questions,
How do you remove the needles from the cluster?
I have the cluster out and in front of me. Removed the clear plastic and the black backing behind that, I am just stuck on removing the needles so I can remove the backing.
If anyone has AIM, IM on RedLX92, or reply. A how to would be appreciated.
check the how2 on www.maximadriver.com
DON't REMOVE THE NEEDLES!!!!! you don't need to remove the OEM dials either....just slide your indiglo dials on top of the OEM ones (first remove all the screws) and secure with double sided tape. I've had no problems with my indiglos so far
My Maxima is a 98. What I have a problem with is not the indicator needle, but the needle that sticks outward, and prevent, the tach/speedo needle from goin all the way down. The alignment is off. When I try to bend it, and get it in, the alignment is off, and it looks funky.
Do they make different ones for 1998-1999? I read on MaximaDriver.com that there is slight difference.
Someone let me know if they wanna buy these for the price of what the new ones run. I bought em on eBay, and you could buy the ones for my year and you could have mine.
Re: Nope
No, I didn't take off my needles. I slipped the tach gauge on and it didn't fit right, so I took it off.
Where can I find a place that sells the right gauges?
umm...initial k is the only company that makes the right indiglo's...they should have gone on perfectly...mine did...try it again...or take a picture of it so we can see
goto www.maximadriver.com and go under group buys...there should be a link to their website
I bought my from Initial K from ebay. The packing of mine looked cheap too. The instructions was a blurry photocopy....check if the bottom of the gauges have a small "Initial K" print
I must not have the right one then. I have one that plainly says,
EL
Luminescent Gauge Kit
Thats all it says, pretty cheap looking packaging too.
Does anyone have a link to where I can buy the initial K ones?
EL
dutch078
Wheels/Tires
08-03-2015 06:58 PM
