short curcuit???
Old Aug 10, 2001 | 01:56 AM
MikeyMax's Avatar
I was reinstalling my TV after adjusting the color...when I hear a "pop" then my readio died, and the "beep" sound that comes on when the door is open died...as well as the clock. The biggest problem is that my engine won't start... but the headlights work. I checked the fuses in the left dash above the left leg...but they seem to be fine. Could anyone help me??? PLEEEAAAAZE.
Old Aug 10, 2001 | 02:04 AM
mk dema
I've had that problem before too, it turns out that the negative terminal on my battery was a bit loose, take a look at both of your battery terminals and make sure they are tight.
That's my two cents.
goodluck
Old Aug 10, 2001 | 04:07 AM
Daniel B. Martin's Avatar
Raise the hood. Locate the fuse and link box. This is a long narrow black plastic box adjacent to the battery. Use a flat-blade screwdriver to release the latches and lift off the cover. Check the fuses and links found there.
jmlee44
Oct 2, 2022 02:13 PM
gigabyte
Jan 6, 2017 06:05 PM
sliptap
Sep 30, 2015 05:57 AM
lux97Max
Sep 28, 2015 11:18 PM
