Tranny Problem
Old Aug 10, 2001 | 08:22 AM
QikEnuf's Avatar
Tranny Problem..looking for more details..
Just got a call from my shop and they have the tranny down and they found out it's leaking gear oil, so now it has to go to a transmission shop to get that fixed, apparently there are some seals on the inside or something like that..maybe DBM can explain it better for the manual tranny on a 96 5 spd.
So I am out another day...oh well...gotta get fixed
Old Aug 10, 2001 | 10:45 AM
QikEnuf's Avatar
Re: Tranny Problem..looking for more details..
Anybody...possible a website that has a diagram (probably doubtful) I wish I had a service manual right now...
Old Aug 10, 2001 | 10:54 AM
krismax's Avatar
Father of the 00 VI
What are your simptons?
Mine are gear grinding at higher rpms ,mostly 3rd gear.
Old Aug 10, 2001 | 11:05 AM
QikEnuf's Avatar
It was leaking gear oil, and I was told that all the seals are inside, the tranny is already out of the car.
Just curious what seals are leaking or if it's the bearings...
Old Aug 10, 2001 | 01:03 PM
Daniel B. Martin's Avatar
There are four seals in the 5-speed transmission ...
- input shaft
- shifter control rod
- driver side axle
- passenger side axle
The input shaft oil seal is the only one which requires disassembly of the transmission. Since your clutch job mechanic wants this seal replacement to be done by a transmission shop, it is probably the input shaft seal which is leaking.
This calls for a careful inspection of the bearings. Transmission oil seals rarely leak, and when they do it is often because the bearing has excessive free play allowing the shaft to move around and wear the seal. The oil leak is like the canary in the coal mine; it is warning you about a bigger problem. Don't ignore this warning.
Old Aug 10, 2001 | 01:07 PM
QikEnuf's Avatar
Re: Re: Tranny Problem..looking for more details..
Hopefully not too serious of a repair, the funny thing is the tranny shop told my mechanic that the 96 was the only one that made all the seals internal? Is this correct?
- input shaft
- driver side axle
Old Aug 10, 2001 | 01:10 PM
Re: Re: Re: Tranny Problem..looking for more details..
No.
Old Aug 10, 2001 | 01:12 PM
QikEnuf's Avatar
Re: Re: Re: Re: Tranny Problem..looking for more details..
You may or may not know this, but do you think they would replace the bearing as well, he indicated it would be $500-600 repair?
No.
Old Aug 10, 2001 | 01:26 PM
Go to http://www.motorvate.ca/
Click on Transmission (in the left window).
Scroll the left window down.
Click on Disassembly (in the left window).
Scroll down to the photo legend which reads "Left: Remove the input shaft, main shaft, and 1-2 shift fork as one unit."
Look at the photo on the left. There is a black ring at about 9 o'clock in the photo. That is the input shaft oil seal.
This site is one of the best I've come across. You may enjoy browsing it.
Old Aug 10, 2001 | 01:43 PM
$500-$600 repair
IMHO the transmission shop should replace all the bearings and all the seals for that kind of money... but don't count on it.
Old Aug 10, 2001 | 02:23 PM
njmaxseltd's Avatar
[QUOTE]Originally posted by Daniel B. Martin
[B]Go to http://www.motorvate.ca/
Daniel, this is one of the best down to earth trans rebuild sites I've seen. I did my Honda once and can totally relate.
2 points!
pktaske
May 6, 2016 07:49 AM
Socalstillen
Sep 20, 2015 11:46 PM
iamute
Sep 20, 2015 05:22 PM
pktaske
Sep 4, 2015 08:40 AM
Lowered_a33
Sep 1, 2015 07:49 PM
