got a lil prob... leaking sunroof...
Old Aug 10, 2001 | 12:28 PM
ShortT's Avatar
so come to find out i have a lil leak in my sunroof... i took it to a body shop, and there it was gonna cost me at least a grand, if not more to get it fixed... he gave me the number to another place, and im gonna check the phone book, but has anyone else ever had this prob? and if so, how much did it cost to fix? cuz this is gonna be a minor setback to the mods i wanted to start on...
Old Aug 10, 2001 | 02:20 PM
Dreizehn's Avatar
What work was he going to charge you for???
Old Aug 10, 2001 | 02:34 PM
njmaxseltd's Avatar
Look in the corners of your sunroof cut out on the car. You should have drain holes there. Make sure there clear, you may even have to blast them out to get them to clear. Had this problem with a Honda I had. The roof does drip slightly into the rim, but is supposed to drain out. Don't give the body shop a dime. Clean out your drains.
Old Aug 10, 2001 | 04:08 PM
Daniel B. Martin's Avatar
Originally posted by njmaxseltd
... Clean out your drains.
This is good advice. If all else fails you can seal the sunroof permanently. It will never open again but that's less expensive than a $1K repair.
Old Aug 10, 2001 | 07:37 PM
ShortT's Avatar
thanks for the advice! u may have just saved me $1000...
Old Aug 11, 2001 | 08:26 AM
sp6040's Avatar
leaking sunroof
i have the same problem i thought it was the rubber gasket around the window i used a rubber sealer didnt work i tried using washersto lift the sunroof window a little higher cause it was sagging on one end a little i thought this would fix it for sure but nope.ohwell a slight leak when it rains heavy.the sunroof cover will get a little damp but thatsall.ijust gave up i didnt even try to bring it to the dealer they will propbably tell me i need to have the whole sunroof replaced.ill just deal with the problem.
Old Aug 11, 2001 | 01:35 PM
24KP-I-M-P's Avatar
$1000 for fixing a sunroof who are they joking we should start a max auto body shop where the labour is freeto maxima owners just share your tips and advice and help everyone save a bit of moeny
Old Aug 11, 2001 | 02:22 PM
mo'max's Avatar
Leaking Sunroof
ShortT -
This link may answer a few questions and even save a few bucks. I had the problem and fixed it for $0.00. Maybe you can too.
http://forums.maxima.org/showthread....hlight=sunroof
hope it helps, good luck.
Old Aug 12, 2001 | 04:12 AM
sp6040's Avatar
leaking sunroof info
thank mo'max this is really usefull info for future references..one question where are the drains located? that maybe my problem since the sunroof fully operates i may have clogged drains..thanks
Old Aug 12, 2001 | 07:04 AM
ShortT's Avatar
hey, thanks guys for all the help! its really appreciated... i found my drains, but i dont think theyre the problem... im gonna clean em out real good though just in case.
Old Aug 12, 2001 | 08:46 PM
mo'max's Avatar
drain locations
SP6040 -
Check the link in my post above. The first time I posted a response to Roman-dude I referred to another link to Tim. The answer is there. You may want to pick up a FSM.
Old Aug 13, 2001 | 04:07 PM
sp6040's Avatar
drain locations
thank mo'max i'll have to check and see...
litch
123
Jan 4, 2024 07:01 PM
aw11power
Oct 10, 2021 04:57 AM
Mar 12, 2020 12:06 AM
followthadollar
Sep 17, 2015 06:31 PM
