ecu code 0505......???
Old Aug 11, 2001 | 09:57 AM
Soon2BMaxed's Avatar
DTC 0505
Diagnostic Trouble Code 0505 is "All Clear". It means the Engine Control Module is working and no trouble codes have been set.
However, Diagnostic Trouble Code 0505 does not mean nothing is wrong with the engine. All it means is that the Engine Control Module has not recognized a problem. There are some aspects of engine operation which the ECM does not check and therefore cannot diagnose. One good example is fuel pressure. There is no fuel pressure sensor, so there are no "low fuel pressure" Diagnostic Trouble Codes.
that is the code i got so what should i check????
Old Aug 11, 2001 | 10:09 AM
Daniel B. Martin's Avatar
More information please
Originally posted by Soon2BMaxed
DTC 0505
When posting a technical question it is helpful if you provide as much detail as possible.
Odometer reading?
Mods, if any?
Recent repair history?
Symptoms?
emax02's Avatar
DTC 0505
Nothing
Old Aug 11, 2001 | 10:13 AM
95SE 5spd 97k no mods or repairs runs perfect.....
Old Aug 11, 2001 | 10:21 AM
... so what should i check????
Engine oil level.
Transmission fluid level.
Coolant level.
Brake fluid level.
Clutch fluid level.
Power steering fluid level.
Windshield washer fluid level.
Tire air pressure (including the spare).
Old Aug 11, 2001 | 10:25 AM
emax02's Avatar
Originally posted by Daniel B. Martin
Engine oil level.
Coolant level.
Brake fluid level.
Clutch fluid level.
Or maybe that stuff..
Old Aug 11, 2001 | 11:10 AM
gtr_rider's Avatar
192.168.1.1
OMG....
This is the worst post in Maxima.org History
Soon2BMaxed
Old Aug 11, 2001 | 11:56 AM
bill99gxe's Avatar
Evil Administrator - "The Problem"
DTC 0505
Do you comprehend the above sentences?
It means NOTHING is wrong, unless your flux capacitor is bad.
I deemeth this post one for the history books.
Old Aug 11, 2001 | 12:06 PM
ok a$$holes i posted this becaues the code said that it was an "all clear" sbut there MIGHT be other problems so i didn't know what else to check. geezus christ u know i envy most of u guys because u all seem to know ur ****. i'm sorry for being a friggin' amateur... daniel b martin thanks at least u aren't a d1ck
Old Aug 11, 2001 | 01:32 PM
bill99gxe's Avatar
"Might" means it's only a possibility. It's almost as if you are trying to find something wrong with the car. You yourself posted that it runs "perfect".
Calling people names for the fact that you can't comprehend simple sentences is not a mature approach to things. There's no need for the name calling or taking the Lord's name in vain.
Since the Max ain't broke, don't fix it. Concern yourself with other much more important matters in life.
Old Aug 11, 2001 | 06:05 PM
ok guys i apologize...once again i opened my mouth without thinking and i'm sorry. i wasn't wanting anything to be wrong with the car its just i was thinking "why the he11 would the check engine light come on if there wasn't anything wrong?" so i wanted to make it very clear that nothing was wrong and since the ecu code said that things "could" be wrong i wasn't sure what it meant. i mean i don't know what the ecu does or doesn't check on and that was why i wanted to know what to check. anyways thanks again for the info and i'm sorry for being a jerk
gtr_rider hehe j/k!
Old Aug 11, 2001 | 06:32 PM
gtr_rider's Avatar
192.168.1.1
No Prob BOB!
gigabyte
Jan 6, 2017 06:05 PM
maxinout93
Oct 31, 2015 02:04 AM
Kyle Lee Cleveland
Sep 28, 2015 09:01 PM
dshinn
Sep 26, 2015 08:07 PM
