Headlights
Old Aug 14, 2001 | 06:21 AM
asianmotorsports2000's Avatar
Is there an adjustment screw to "aim" the headlights? My passenger side appears to be aimed lower that the driver side. Also, is there one for the fog lights on a SE?
Old Aug 14, 2001 | 06:32 AM
Albertt's Avatar
Lamp adjustment screws >>
Are located behind the headlamp housing. For the 4th gen, they are of the post type (requiring an 8mm wrench), extending out of the housing bracket, and are located low on the outboard side and high on the inboard side (near the radiator). 4th Gen lamps are externally aimed (meaning the entire housing moves when the lamp is adjusted). 5th Gen owners are lucky enough to have the internally aimed HB2 housings. Like the 4th Gen lamps, there are two adjustment points for vertical and horizontal position, but in the 5th Gen they are configured as ***** requiring a Philips head screwdriver.
Both 4th and 5th Gen foglamps are adjustable with a single screw located in the back of the housing. Adjusting this screw alters the vertical AND horizontal position of the lamp, so take care when performing the aiming operation.
doctorpullit
Oct 28, 2019 10:58 PM
trsandrew
Apr 8, 2016 06:45 PM
knight_yyz
Nov 1, 2015 01:34 PM
trsandrew
Oct 25, 2015 02:47 PM
Noela
Sep 26, 2015 08:22 AM
