Blown Fuse
Old Aug 14, 2001 | 02:06 PM
WaarrEagle's Avatar
Today I installed my blue washer lights and they worked fine for a little while but then I blew a fuse. My corner lights, washer lights, and tail lights don't work. I found the blown fuse and it was a 7.5 amp. I am going to replace it but I wonder if I should hook the washer lights up to some other source. I have my corner lights in backwards so they are brighter and I am thinking I might be putting too much through the wires. Anyone have any imput on if I should move them or do you think I have a short somewhere? Thanks.
Old Aug 14, 2001 | 02:15 PM
NeverEnough
more than likely just too many amps for the fuse
Try running them through another source, such as the cig. lighter fuse, it should be able to handle the additional draw, unless you run a high draw component through it, i.e. a cell phone charger, etc. If you want to check for a short, make your own fusible link, put in a 10 amp fuse, ground the washer nozzle bulbs and hook it up to 12 volts. if it blows, there is a short, if not, it should be ok. Hope this helps. Let me know if it doesn't.
Lee
ps....WAAAAAAAAAR EAGLE (I'm from 'bama, and I've ALWAYS been an Auburn fan, and will be 'til I die)
Old Aug 14, 2001 | 03:53 PM
WaarrEagle's Avatar
I did find the problem when I looked around. I was trying to secure to wire from the hood to the corner lights and I hooked them under some bolts and when I bolted them down some of the wire got forced through the insulation and then I guess it shorted out. I got everything back together and havn't blown anything but I haven't operated them for a while yet. Hopefully I won't have any more problems. I had to replace the 7.5 fuse with a 10 because thats the closest I had. Should I get a 7.5 or is 10 OK?
Old Aug 14, 2001 | 06:09 PM
Daniel B. Martin's Avatar
... Should I get a 7.5 or is 10 OK?
Get the 7.5 amp fuse.
Old Aug 15, 2001 | 01:08 PM
NeverEnough
Never change the rated fuse value in your fuse box....you can burn up your car.
leatherneck
Sep 30, 2015 09:16 PM
homewrecker
Sep 24, 2015 07:01 PM
conansriver
Sep 16, 2015 12:17 PM
Maxie40
Sep 14, 2015 11:28 AM
