.5 sec. slower in 1/4
Tonight was the first time I ran the quarter with my new Apex Ws catback. I expected maybe one or two tenth tenths quicker, but damn, it ran half a second slower. It was at the same track and about the same temp. The only thing I can think of is the 02 sensor I didn't put back on the new pipe. Could this sensor slow me down that much?
It was close to the same reaction & 60' times. I ran the car 3 times and every time, the same result. The bottom end feels better than before as far as response so I wouldn't think that it has no backpressure. Any more ideas? Thanks for your feedback.
Other Mods?
Re: Other Mods?
Originally posted by SuDZ
Is this the only mod you have been doing to your car lately? Nothing else that would affect weight or anything or even other mods you have done between now and then?
Re: Re: Other Mods?
The only thing else I have done was to tap into my Vehicle speed sensor to remove my speed limiter.
...of course, you drive an SE, so you didnt have a speed limiter to begin with. You hacked up your ECU harness for no reason. Have a nice day.
![Smilie](https://maxima.org/forums/images/smilies/smile.gif)
Re: Re: Other Mods?
SuDZ
Having no rear O2 sensor will hurt your performance. I'm surprised your ECU hasn't thrown a code. By not running the rear O2 sensor, the engine will run richer in the upper rpms because it is not getting the correct readings. As your rpms climb, you want the engine to run leaner in order to make good power.
Dave
Dave
Re: Hmmm . . . .
Originally posted by dwapenyi
IIRC the rear O2 sensor is mounted after the cat and makes sure your cat is working properly. Your sig mentions a gutted cat. If the cat ain't workin', you must aquit![Smilie](https://maxima.org/forums/images/smilies/smile.gif)
DW
DW
Re: Re: Hmmm . . . .
OK. Nix the cat suggestion. As for your 120 mph thing, I can suggest these 2 things;
1) keep your car in 3rd gear as long as possible, OD off etc. I'm not certain of the procedure, you're an auto and I'm a stick, but its something like that.
2) Change your feul filter if you havne't done it in 30K miles or so. When I originally got my car, I couldn't get past 125 mph. Replaced the feul filter and bam! 140!
DW
DW
But I ran the car with the gutted cat before the Apex was put on and I ran my best times ever. I guess i will get that sensor put back in. Oh yeah, thanks ben for your ghetto mods, and yes I did hack up my computer for nothing. The reason I thought that I did have a speed limiter is because I could'nt get the car past 120. But after doing this mod it didn't change a thing. So I just left the switch in the car since I already drilled a hole for it.
You probably have your foot to the floor when you hit 120 (its the top of third gear). Let go of the gas a little and let it shift into 4th. From there, feather the gas until you keep climbing. Oh, AND DRIVE SAFELY!!!
DW
DW
Yeah I need to change my fuel filter(it has 65,000 miles on it. Do you think that I could benefit from a Fuel pressure riser or a bigger fuel pump?
This is easy
It's time to join SMC Racing..
sign up in the thread in the general forum
on another note.. there are a few SMC members who posted in this thread and havn't suggested joining SMC ... i'm disappointed![bawling](https://maxima.org/forums/images/smilies/bawling.gif)
And Iron: rear O2, put it in then come back and talk to us![Big Grin](https://maxima.org/forums/images/smilies/biggrin.gif)
Ant
Ant
Re: This is easy
Ant
Ant
SuDZ
65K miles on 1 fuel filter? Holy cow! CHANGE IT NOW! You are going to notice a big difference!! Also, if you're like me, you don't want to have to deal with that feul filter so often. The last time I changed mine, I put in a 300ZX filter. It's twice the size of the Maxima one, so you'll get a longer change interval before you have to change it again.
As for the pressure riser and feul pump upgrade, I wouldn't really know. I would think that you would need those only if you were planning on going S/C, or turbo. Applications which significantly increase your need for feul.
DW
DW
I have no rear O2 sensor and have had 94 mph traps.
I think anything from weather to track conditions could be the cause.. I think you should be careful to make sure that you have low front tire pressure as that can make a difference. and change your fuel filter before your car gets angry at you
MattWithTheMaxima
06-30-2017 01:06 PM
ag90fox
09-09-2015 12:22 PM
