Abs Warning Light!?!?!?!
Old Aug 16, 2001 | 09:33 AM
Alex97se's Avatar
About 30 minutes ago I had my 97 maxima inspected, everything went well, and I passed. On my way home, I looked down on my dashboard and noticed that my ABS warning light was on. What the hell?
p.s. mileage = 69,000
Old Aug 16, 2001 | 09:59 AM
dwapenyi's Avatar
ABS
Let me guess, when your car was inspected, the front wheels were moving and the rears were stationary?? Your ABS got 'confused.' Turn off the car and start it up again. ABS will do its routine check and the light should go away this time.
DW
Old Aug 16, 2001 | 10:10 AM
Daniel B. Martin's Avatar
Does your state's inspection procedure involve running the car on rollers? That can turn on the ABS warning light because the front wheels are turning, the back wheels are not, and that makes the ABS control unit grumpy.
Old Aug 16, 2001 | 10:25 AM
njmaxseltd's Avatar
Same happened here. I didn't even get out of inspection when I noticed it, so I asked the guys what the hell went wrong? They told me why it was lit. Now you'd think that perhaps when they inspect vehicles and throw a warning light they just might take a sec. to explain perhaps why that happened?????
Old Aug 16, 2001 | 11:43 AM
Alex97se's Avatar
thanks for the info guys. the light turned itself off
Old Aug 16, 2001 | 11:53 AM
Alex97se's Avatar
Old Aug 16, 2001 | 02:50 PM
dwapenyi's Avatar
Re: if it ever goes on again...
I think you're talking about the airbag warning light . . . . .
DW
Originally posted by Gary95
You can manually reset this light too. It's a quirky procedure of clicking the driver's door sensor/switch a few times. Worked for me, saving the cost of a Nissan mechanic to do it for me at $65/hr. Don't recall the exact steps off hand, but a few of the regulars here know it.
Old Aug 16, 2001 | 04:21 PM
ABS warning light reset instructions
1) Turn the ignition switch OFF.
2) Identify terminal 4 of the Data Link Connector. This connector is found at the right hand edge of the passenger cabin fuse block. The fuse block is located in the lower dashboard, behind a pull-out panel near the driver's left knee. The Data Link Connector has two vertical columns of contacts, with each row having seven contacts.
Terminals 1 - 7 are in the left hand column, with terminal 1 at the top.
Terminal 4 is the fourth from the top.
3) Use a test lead and a bent paper clip to ground terminal 4. This grounding must be done three times in succession within a 12.5 second time span. Each of the three groundings must be longer than one second.
For more information please refer to the Chilton repair manual (page 9-17,18) or the Haynes repair manual (pages 9-3,4). Chilton and Haynes refer to Terminal 4 as Terminal L. The factory service manual designates it as Terminal 4. It is the same terminal.
mvm062
Nov 30, 2020 09:00 AM
bbsitum
Sep 6, 2019 07:31 PM
captchaos
Mar 15, 2016 12:18 PM
Maxie40
Sep 14, 2015 11:28 AM
maximusrising
Sep 2, 2015 09:55 AM
