Keep Old Speaker Grilles Or New Ones?
Old Aug 21, 2001 | 02:24 PM
Vyrus's Avatar
I am getting my Boston speakers installed this Friday, and I was wondering whether I should use the factory grilles or the Boston Grilles. If I use the Boston grilles will there be any extra screw-holes or marks from the previous ones? I had the factory non-Bose system.
Thanks,
Cyrus
Old Aug 21, 2001 | 02:25 PM
97GreenMax's Avatar
If I were you, I would keep my stock grilles, I think it would look cleaner. Just my .02 though.
Old Aug 21, 2001 | 02:39 PM
breaux124's Avatar
When I replaced my speakers, I kept the stock grills for the midrange, but replaced the grills on the tweeter.
http://www.users.voicenet.com/~breaux/car/dscn0158.jpg
http://www.users.voicenet.com/~breaux/car/dscn0157.jpg
If you're just getting the speaker, then don't go through the trouble of replacing the grill. I mean the tweeters weren't too bad, but the main door grills would have been a pain.
Old Aug 21, 2001 | 04:26 PM
MaXAnDy's Avatar
i think the stock grills look better.
Old Aug 21, 2001 | 04:29 PM
sp6040's Avatar
mb quartz
those little tweeter grilles look cool. yeah i would keep the stock speaker covers..
Old Aug 21, 2001 | 04:33 PM
thebigsadler's Avatar
Re: mb quartz
as far as i know the grills are different sizes.. stock grill are not for 6.5's atall.. and when speakers come with tight fit grills youd have to have the door reupholstered.. as far as tweeters.. definately replace those
Old Aug 21, 2001 | 05:05 PM
Nathan's Avatar
breaux124, your MB Quart tweeter covers look really nice
Old Aug 21, 2001 | 05:27 PM
riggy's Avatar
no doubt........
Old Aug 21, 2001 | 06:37 PM
MarcJD's Avatar
Definitely keep your stock grilles on. Bostons have different size grilles and they won't fit properly in the back and on the doors. There will be screw holes exposed and weird track marks from the old ones if you put the Boston ones there. I had to make this decision when I got Bostons and after looking at it with the Bose one off and the Boston, there was just no second guessing it.
Old Aug 22, 2001 | 06:34 AM
breaux124's Avatar
I wasn't originally going to replace the stock tweeter grill to prevent extra attention to them. But the way the stock tweeter was mounted was a little strange, so I just decided to use the MB Quart grills.
Replacing the grills in your car with aftermarket grills will drawn added attention to "other" people. I've known people who have gotten there speakers stolen cause of this.
When was the last time someone tried to steal stock speakers?
Old Aug 22, 2001 | 10:06 AM
Vyrus's Avatar
Speaker Grilles...
Thanks for all the help guys. Can I just leave the grilles off and put the screws from the factory grilles back in? Would that just plain look tacky? Thanks in advance,
Cyrus
Old Aug 22, 2001 | 10:14 AM
breaux124's Avatar
Re: Speaker Grilles...
Cyrus
The grills are part of the door cover in the front, and are attached to the rear panel piece in the back?
Have you tried to replace the speakers?
The stock grills have no screws at least not that I can remember. Maybe your car is different. If you remove the door panel the grill are attached to that and they don't require any screws.
The only screws needed are the ones to put the speakers in.
Old Aug 22, 2001 | 10:31 AM
Vyrus's Avatar
RE: Breaux124
So if I put on the new grilles the only difference is that I will have a slight carpet line where the old speaker grilles used to be in the rear and they will not be the triangular shape in the front? Thanks again,
Cyrus
Old Aug 22, 2001 | 10:47 AM
breaux124's Avatar
Re: RE: Breaux124
Cyrus
I think the stock grills are larger than most aftermarket grills. I don't think it'll look right.
I would save myself the hassel and just put the speakers in with the stock grills. I'm not sure how much would be involved in fitting the aftermarket grills.
I looked at my car and in the front it looks impossible, unless you do alot of work to the door, or let it look like cr@p.
Old Aug 22, 2001 | 11:03 AM
Vyrus's Avatar
RE: Speaker Grilles...
Maybe I'll just take advise from Mike (my installer). He does hundreds a week so he should probably know best right? Anyways, thanks Breaux124 you made me consider more carefully.
Later,
Cyrus
Old Aug 22, 2001 | 11:10 AM
breaux124's Avatar
Re: RE: Speaker Grilles...
Later,
Cyrus
yeah listen to the installer
I replaced the grills in my old car, and they just never looked right. Go with what the pro says.
Old Aug 22, 2001 | 02:46 PM
Vyrus's Avatar
By the way...
How good are Boston Acoustic speakers? They guy I bought them from reccomended them to me the second I walked in. I was looking at more expensive ones, but he said that Boston Acoustics are very nice? True??? Thanks,
Cyrus
Old Aug 22, 2001 | 03:01 PM
breaux124's Avatar
Re: By the way...
Cyrus
yeah they are good. It also depends on what level you bought. If they sound good, that's all that matters.
In my car(s), I've gone from stock, to sony, to infinity, to OZ, and now to MB Quart. I can hear subtle differences that make me want the upper level speakers.
Play music without much bass, and then some with strong bass at normal volume. Then do it again at a higher volume. Do the highs crack? Do the speakers bottom out? It also depends on other things like power and crossover points and signal level. So many things affect the sound of a speaker.
REDinLV
Aug 15, 2024 12:30 AM
magiconthetire
Oct 26, 2015 09:03 PM
Kyle Lee Cleveland
Sep 28, 2015 09:03 AM
Kyle Lee Cleveland
Sep 28, 2015 07:58 AM
ricky7780
Sep 24, 2015 06:50 PM
