Procedure to disable Anti-Theft System
Old Aug 21, 2001 | 04:09 PM
texmax
The Anti-Theft on 4th generations has a Relay swith to disable ignition if activated (relay located on passenger side of engine bay near right strut, look for "Anti-Theft/Start" on the relay box cover). When tripped it will ground power to the Inhibitor Relay that controls the starter solenoid.
THEFT DETERRENT SYSTEM
To cancel the system and prevent accidental activation, perform any one of the following:
1) Using the key, unlock either the driver's or passenger's door.
2) Using the multi-remote control system, if installed, unlock doors.
3) Turn the ignition to the ACC or ON position.
4) Using the key, unlock the trunk lid. The system is only temporarily canceled while the trunk lid is open. After the trunk lid is closed, the system is reset.
5) To set the system, remove the key from the ignition, and close the doors, trunk, and hood. Then lock all doors either manually using individual door lock buttons, or activate the power lock system with either the key or the multi remote control system.
Old Oct 7, 2014 | 07:05 AM
thabrock's Avatar
keys
are we using 2 keys to reset the alarm? ACC and Trunk simultaneously?
Miket2006
Mar 1, 2021 03:55 AM
MichMaxFan
Sep 30, 2015 09:18 AM
Socalstillen
Sep 26, 2015 12:01 PM
A32goldylocks
Sep 2, 2015 06:39 AM
