Anyone get this chirping spound?
Chirping sound? Any ideas?
It seems that I only hear it when its warm outside at any speeds. Does not do it unless the car is moving. It seems to be coming from either behind the dash, in the wheel well or in the engine comaprtment in front of the driver. Any ideas? I have a 97 max with 62k. I did have the front struts replaced about 6 months ago. I doubt its that. I do have squeeking brakes however. Could it be that brake pads are loose. I doubt this too because I have heard the chirp while braking. Any ideas?
lately, i hear this damn chirping noise coming from the engine compartment with my headlights/fogs all on, on cool nights (like 50 degrees or so). I pulled up next to parked cars, and push on the gas, and it makes this sick squeak/chirp type noise. So i got out, pulled the parking brake REALLY hard, and opened up the hood, and revved it from under there, and i could hear the noise coming from inside the plenum manifold (along with the normal air rush noise). Dunno what this could be, and if its related to my squeaky pulley (even though it didnt seem like the chirp was coming from the pulleys). Help! car goes in to dealer on tuesday
I was thinking of that too...i do have a rough idle, adn when i put my car in reverse, i hear a "thunk" sound coming from the front area. However, its weird since my car idles at 650 in drive MOST of the time, and sometimes it is very nice and smooth. Then i could turn the car off, run an errand, and come back, and the car woudl idle rough at stop lights (all while in drive or reverse of course).
Yes, while in park, if i hit the throttle up to say, 1500 rpms, and while its coming back down, i hit it again, it will make the chirp noise. i should also note that when I am in drive, and if i'm driving alongside a large brick wall or a whole bunch of parked cars, and i hit the gas from start, it makes the noise for a couple of seconds, which is quite long! However, if I am already at 1000rpms, and i'm holding it steady, I dont think it will make the noise when i hit the gas harder and rev to 2000.
Re: Chirping sound? Any ideas?
- a stone caught in the brake caliper area, rubbing on the rotor
- a splash guard bent so that it touches the rotor
- a brake shim which has escaped and is touching the rotor
- a dry wheel bearing seal
- Constant Velocity joint
- axle support bearing (passenger side only)
MaximaDrvr
Aug 19, 2015 08:20 PM
jnm2kse
40
Jul 24, 2009 02:19 PM
jnm2kse
28
Nov 6, 2000 12:23 PM
