apex springs
Old Sep 5, 2001 | 06:05 PM
cerumo's Avatar
Does anybody know where I can get apex springs and how much they are?
I heard they do drop like sprint with much better ride.
thks.
Old Sep 5, 2001 | 09:35 PM
97GLES's Avatar
thks.
apex has a 1.6" drop. they are lower than eibachs and h&r but can not be compared to sprint or intrax that have a 2" drop which is not good for a maxima. they run about $200. call AUDIO LINKS at 201-420-6792( 11am-6pm new york time) ask for Freddie.
Old Sep 6, 2001 | 08:48 AM
cerumo's Avatar
Are they apex springs in the maxima picture shown?
I will use these springs with my stock struts for about 6 months. Do you think the ride will be really bad?
thks.
Old Sep 6, 2001 | 06:58 PM
97GLES's Avatar
thks.
yes the piture has the apex springs. with any lowering springs you should change the shocks as soon as possible. with the stock shocks your car will bounce. do your-self a favor don't buy tokico shocks.
Old Sep 6, 2001 | 07:03 PM
97GLES's Avatar
thks.
Old Sep 6, 2001 | 07:33 PM
philthismax's Avatar
I would like to say your car looks hot. And want to ask y is a 2"inhc drop bad for the max. I was thinking of geting the sprints for my max and what struts do you recommend if i go with apex.
Old Sep 7, 2001 | 05:51 AM
97GLES's Avatar
the maxima front suspension is not as good as other cars. sprint springs are made in the u.s. and are cheap and you will always get that bounce that they produce. i have seen the sprint springs for as low as $119 for a set, you will never see that with eibachs or h&r or apex, it cost them more to make and to import. shocks, try to get the koni's or agx when they come out. good luck on your pick.
Old Sep 7, 2001 | 06:19 AM
loup1276's Avatar
what about the gr2 with apex how do you think they will hold up as for myself i am getting impatient with the agx the dates keep getting pushed back father and farther.. are the gr2 stiffer than stock..thanks
Old Sep 7, 2001 | 07:27 AM
njmaxseltd's Avatar
The gr2's are slightly stiffer then stock. I'll be doing the H&R and gr2 setup this spring. H&R's will go in this fall, and the gr2's will go in next spring. My car only has 32K on it so the stock shocks/struts are still nice and tight and should be fine with the H&R's for a while.
Old Sep 21, 2001 | 10:01 PM
black019's Avatar
sprints will fit an I30 right? I have a 98...
Old Sep 21, 2001 | 10:15 PM
Nathan's Avatar
I'm running my apex springs on stock SE struts and the ride is actually very good. I only have around 55000 km's on the struts so they're still pretty tight. The ride is not harsh at all as I have been hearing about the Intax and Sprints. The drop is also very nice but not too low which is good if you live in areas with high curbs.
Old Sep 21, 2001 | 11:20 PM
Nismo's Avatar
is there an online place where I can buy these?
Old Sep 21, 2001 | 11:24 PM
NYCe MaXiMa's Avatar
there probably is, but won't you rather get them from a trusted fellow Maxima.org member?
really...
Old Sep 22, 2001 | 06:32 AM
97GLES's Avatar
really...
if you need a set of the apex springs give me a call at AUDIO LINKS at 201-420-6792 from 11am-6pm new york time.
retail on them are about $265.
i'll call apex on monday and get a price for you, just give me a call when you have chance.
MaxLvr21
Oct 17, 2015 12:11 PM
JakeOfAllTrades
Oct 5, 2015 10:40 AM
MaxiNoob98
Oct 2, 2015 10:13 PM
JakeOfAllTrades
Sep 30, 2015 03:16 PM
followthadollar
Sep 27, 2015 01:06 PM
