Is my O2 sensor damaged
Ok guys.. I was wondering how you would know if your O2 sensor was damaged... I used a Fuel Injector Cleaner a few months back and I noticed a slight decrease in performance. But I'm not sure if it's just me....
You may have your Oxygen Sensor(s) tested. There are electronic testers made for this specific purpose. In addition, a technician with an automotive oscilloscope can test Oxygen Sensors. The signal from a healthy sensor varies from a low threshold (around 0.2 volts) to a high threshold (around 0.8 volts), and it sweeps back and forth between those extremes about 10 times per second. If the scope trace shows the Oxygen Sensor signal failing to reach either extreme, or oscillating between them at a frequency slower than 10 cycles per second, that is evidence of a "tired" sensor. A "tired" sensor is one which is still doing its job, but not very well.
Originally posted by Daniel B. Martin
Your Maxima has three Oxygen Sensors. There are two "front" Oxygen Sensors, one mounted in each branch of the Y-pipe. There is one "rear" sensor mounted just downstream of the Catalytic Converter. The Engine Control Module (the computer) uses the signals from the two front sensors to control the fuel mixture. When the front sensors are operating normally the rear sensor is used only to monitor the performance of the Catalytic Converter.
Now say if you did have an oxygen sensor that was "tired", but still working. Would it cause the check engine light to come on? Or would it go unnoticed? My light came on about 1 1/2 months ago with the codes for front left heated O2 sensor, and knock sensor. I reset the computer and the light hasn't come on since then. But my gas mileage has gone down significantly while driving in the city. And my driving habits are basically the same if not better now.
Dead versus tired
Originally posted by utahmax
Now say if you did have an oxygen sensor that was "tired", but still working. Would it cause the check engine light to come on? ...
1) The Oxygen Sensor is "dead".
The signal from the Oxygen Sensor is outside the normal range, or completely absent. The Engine Control Module (the computer) turns on the Malfunction Indicator Light and stores one or more Diagnostic Trouble Codes. This failure mode is obvious because of the dashboard warning light.
A dead Oxygen Sensor is a severe failure and should be repaired promptly.
2) The Oxygen Sensor is "tired".
The Oxygen Sensor still works but it responds slowly to changes in the oxygen concentration in the exhaust stream. There is no MIL or DTC. This failure mode is less obvious. The symptoms are increased fuel consumption, decreased engine power, and a feeling of sluggishness. The throttle response is not crisp, like it was when the car was new. An Oxygen Sensor may become tired due to high mileage or being "poisoned" by exposure to various substances including leaded fuels, anti-freeze, anti-seize, RTV sealants, and the residue of burned engine oil. A "tired" Oxygen Sensor is still doing its job, but not performing well.
A tired Oxygen Sensor is not a severe failure and the car may be operated safely.
I've read that a bad Oxygen Sensor can sometimes be rejuvenated by removing it, clamping it in a vise, and heating the sensing tip red hot with a propane torch. This is said to burn off a crust of deposits which interfere with its operation. I've never tried this torch trick myself, so cannot vouch for it's effectiveness. If you have a sensor which is already dead, you have little to lose.
For more information about Oxygen Sensors see:
http://www.volksparts.com/o2sensors.htm
http://members.aol.com/carleyware/library/o2sensor.htm
Re: Dead versus tired
There are two degrees of failure.
Thanks for the reply, that helped me out a lot.
my03maxima
07-28-2024 07:40 AM
TallTom
50
07-08-2022 09:54 AM
Kyle Lee Cleveland
09-28-2015 09:01 PM
