exhaust questions
Old Sep 13, 2001 | 01:11 PM
operationNOS's Avatar
well, Im gonna try this again. I need some info about the exhuast for my 96' gxe. I hear alot about b-pipes, y-pipes, cats, and cat-baks. I was just looking for a few details, Im very exhuast ignorant. Can I have a ypipe and a bpipe? and what exactly do y and b pipes do for the exhuast? Anything you can offer is greatly appreciated and thank you for your help.
Old Sep 13, 2001 | 01:55 PM
SuDZ's Avatar
Originally posted by operationNOS
Well here is some of your questions
You came to the right place for help then.
Yes. They are seperate pieces in your exhaust system.
They open up airways in your exhaust by eliminating catalytic ( speeled wrong most likely) converters. By doing this air moves more freely and gives less resistance which means you get more horsepower.
SuDZ
Old Sep 13, 2001 | 02:17 PM
jran76's Avatar
This is you exhaust coming off the exhaust manifold (2) on the engine: Y-pipe--Cat Converter--B-pipe--muffler.
The factory y pipe has 2 pre-cats, those, along with the shape limit air flow. Replacing the y-pipe will simply open your exhaust up, it eliminates the pre-cats. The cat is an emmisions device that also somewhat restricts airflow. A high flow cat (Randaom Tech) again opens things up a bit. A cat back exhaust is a b-pipe and muffler (Apex also refers to a a-pipe as part of the system.
Performance wise the y-pipe will probably make the biggest difference, and the most noise. A cat and cat back exhaust will add some to performance also, and some to the sound. All three will give you substantial gains.
Hope this helps....
Maxboy23
Sep 4, 2015 06:04 PM
TheMafia
Sep 4, 2015 08:26 AM
Johnny9595
Sep 3, 2015 05:18 AM
Justin Kroll
Sep 2, 2015 11:06 AM
A32goldylocks
Sep 2, 2015 06:39 AM
