difference between 3 nissan spark plugs
Old Sep 13, 2001 | 02:45 PM
Monil's Avatar
What are the differences between the 3 Nissan spark plugs?
22401-1P1S4VW
22401-1P1S5VW
22401-1P1S6VW
and which one do you recommend?
Thanks!
BTW, if anyone else needs these, I found these at a OKC Nissan dealership online for $8.58/each (www.nissanautoparts.com).
Old Sep 13, 2001 | 04:00 PM
bill99gxe's Avatar
Evil Administrator - "The Problem"
http://forums.maxima.org/showthread....threadid=45742
Old Sep 13, 2001 | 04:07 PM
Daniel B. Martin's Avatar
22401-1P1S4VW
22401-1P1S5VW
22401-1P1S6VW
Thanks!
I went to www.nissanautoparts.com and plugged in your part numbers... the response was No Such Part.
Old Sep 13, 2001 | 11:21 PM
guido_sst's Avatar
The 1P1S4VWs are a slightly hotter plug, the 1P1S5VWs are stock, and the 1P1S6VWs are a slightly colder plug. Using the 5s should be fine.
PS DBM - The part numbers are correct.
Old Sep 14, 2001 | 03:44 AM
Monil's Avatar
Try inputting those again. It worked for me after a couple of trys.
Old Sep 14, 2001 | 08:07 AM
bill99gxe's Avatar
Daniel,
The part number "order" on that database is xxxxx - xxxxx.
However, appending the "VW" on the end allows the part number and price to come up.
Must be an exception to the rule.
Old Sep 14, 2001 | 09:20 AM
peemoeller55's Avatar
the other guy is rite. 1st one is slightly hotter, 3rd one is slightly colder. go wit the slightly colder one.
Old Sep 15, 2001 | 07:32 AM
Originally posted by bill99gxe
Daniel,
Thanks for the tip. I discovered that I had a trailing blank following the VW. That was enough to cause the www.nissanautoparts.com software to choke. Bad software design, IMHO.
Slamrod
Sep 3, 2015 07:38 PM
Maxboy23
Aug 21, 2015 11:02 AM
Turbobink
Aug 15, 2015 07:20 AM
1992maximase30
Aug 5, 2015 09:27 PM
maxima297
Aug 3, 2015 12:50 PM
