Guage (AutoMeter Install) Questions
Old 09-20-2001, 07:41 AM
ejj
ejj's Avatar
I was thinking of adding guages such as those that theblue has, only with black faces. I was looking to get Fuel Pressure, Oil Pressure and Oil Temp.
Which guages do you guys like? Anyone here install them their selves?
What's involved, what needs to be purchased? I know nothing about this.
Thanks!
ejj is offline
Old 09-20-2001, 09:14 AM
'Trynna' is not a word
mtrai760's Avatar
Re: Guage (AutoMeter Install) Questions
Thanks!
You well need to buy extra wiring, and have a good wiring diagram to find a power wire to use. I installed my fuel pressure and air fuel ratio myself, wasn't very hard at all. check out www.summit.com they have good prices, and www.autometer.com to find the ones you want. Good luck.
mtrai760 is offline
Old 09-20-2001, 09:21 AM
ejj
ejj's Avatar
Re: Re: Guage (AutoMeter Install) Questions
Thanks.
By extra wiring, do you just mean extra wire, or is it application specific?
I've looked at both of those sites, and pretty much know what I want but I can't find anywhere that specifies if they come with the hardware needed to install them (T's or whatever else they need).
If you buy the guage from summit does it come with everything you need for the install (other than that extra wiring)?
ejj is offline
Old 09-20-2001, 12:49 PM
mtrai760's Avatar
Re: Re: Re: Guage (AutoMeter Install) Questions
Thanks.
I meant extra wire, the guages don't really come with any (air fuel comes with a little bit...) You will also need either a guage pod, or get some stereo abs plastic and install them under the stereo like theblue... You might need some T's for the pressure senders and hose also...
mtrai760 is offline
Cotozic
06-28-2017 08:01 PM
PH98I30
08-26-2015 08:24 AM
95Maxi
08-25-2015 08:01 PM
mikekay
08-10-2015 12:52 PM
Quick Reply: Guage (AutoMeter Install) Questions
