Car pulls after FSTB install
Old Sep 20, 2001 | 11:38 AM
playas33's Avatar
I installed an FSTB and my steering wheel & car pulls toward the drivers side...any ideas on what the problem could be??? maybe just need an alignment???
Old Sep 20, 2001 | 11:47 AM
Vinipux's Avatar
Re: Car pulls after FSTB install
did you install it on a flat ground? it could have shifted a bit if it wasn't
Old Sep 20, 2001 | 11:54 AM
VQ Quick's Avatar
Probably alignment.
OR it could be
1. Dented rim? -unlikely
2. Tires could have a some tread seperation.- highly unlikely
3. Your car has been wrecked before and the frame is now tighter and more solid because of the strut bar, thus it directs the car towrad one direction. -This actually happened on my previous 97.
4. Your imagination -most likely not -but the bar does react to steering inputs much better, and the car does display a much crisper turn in.
5. My friend and I are running out of outrageous theoretical diagnoses.
Go get the alignment checked ASAP. Enjoy. And get yourself the Rear sway bar. It really makes your car corner flatter and tighter just in everyday driving.
Have fun
Old Sep 20, 2001 | 11:56 AM
Jeff92se's Avatar
I'm needing a caw
:spock voice: Logic would dictate that you remove the offending FSTB and drive the vehicle again to see if the problem persists. If the problem ceases, perhaps your installation was flawed.
Old Sep 20, 2001 | 12:00 PM
playas33's Avatar
I did install on it flat ground, unless my garage is tilted, Jeff, I think I will see if it still happens when I take off, thanks for the advice guys
Old Sep 20, 2001 | 12:02 PM
bill99gxe's Avatar
Evil Administrator - "The Problem"
what's logic?
Old Sep 20, 2001 | 12:10 PM
njmaxseltd's Avatar
Let us know what happens after you take it off.
Old Sep 22, 2001 | 07:12 AM
playas33's Avatar
I needed an alighnment, apprently my moms took my car out when I was away...gotta hide that extra key from now on. Thanks for the advice guys.
Lakersallday24
Jun 16, 2019 01:35 AM
MaximaDrvr
Aug 19, 2015 08:20 PM
kirkhilles
Aug 8, 2015 10:53 AM
00 Max
Aug 4, 2015 07:09 PM
