engine swap
Old Sep 20, 2001 | 02:29 PM
armin4
engine swap
is it possible to swap a 5 generation engine in a 98 max se?
Old Sep 20, 2001 | 02:31 PM
gtr_rider's Avatar
192.168.1.1
Hardly doubt it!!
Old Sep 20, 2001 | 02:34 PM
Jeff92se's Avatar
I'm needing a caw
Re: engine swap
Yes
Old Sep 20, 2001 | 02:36 PM
gtr_rider's Avatar
192.168.1.1
Re: Re: engine swap
Originally posted by Jeff92se
Yes
huh HOW!!!
Vyrus's Avatar
Yes...
Very possible, as well as a 300ZX swap...but who's going to spend the money? Why not buy a new Maxima?
SuDZ's Avatar
Re: Re: engine swap
Yes
Would be even better to find out about that new 3.5 260 HP in the 2002. Hmm, Would you still be able to do mods like Y Pipe and stuff? Would it change because your no longer using a 199x - 1999 engine? Maybe haev to get it custom. Just thinking about it.
SuDZ
Old Sep 20, 2001 | 02:39 PM
MardiGrasMax's Avatar
Re: engine swap
With the FULL motor control wiring harness, ECU and both years factory service manuals I'm positive it will work.
Old Sep 20, 2001 | 02:41 PM
Jeff92se's Avatar
I'm needing a caw
Re: Re: Re: engine swap
Very carefully
Originally posted by gtr_rider
huh HOW!!!
Old Sep 20, 2001 | 02:44 PM
bill99gxe's Avatar
Evil Administrator - "The Problem"
Jeff,
When you come over this weekend for the VG twin turbo swap in my 99, don't forget the phillips head screwdriver......and bring a jack just in case.
SuDZ's Avatar
Re: Re: engine swap
Yes
Always informative huh?
SuDZ
Old Sep 20, 2001 | 02:46 PM
gtr_rider's Avatar
192.168.1.1
Re: Re: Re: Re: engine swap
Very carefully
SWEET!!!, I smell rubber
Old Sep 20, 2001 | 02:47 PM
Jeff92se's Avatar
I'm needing a caw
Right after I put the new Q45 engine in the 92se. I'm almost done. 340hp na baby! It was easy really. email me for details. I don't want the haters to know how to do it.
Originally posted by bill99gxe
Jeff,
Old Sep 20, 2001 | 02:48 PM
Sonic's Avatar
Don'r forget that annoying little electronic throttle thing, the cable will get jealous.
Old Sep 20, 2001 | 02:50 PM
bill99gxe's Avatar
Oooooo.....upgrade for my 94!
More proof that 3rd gens are superior because they can handle the bigger motors with their higher hoodlines.
I'm glad you had success with that. Did you do the RWD conversion as well, or were you able to shoehorn the Audi Quattro driveline?
I bet the ECU issues sucked, though.....
Old Sep 20, 2001 | 02:52 PM
Jeff92se's Avatar
I'm needing a caw
Shat, that was the easy part. I rigged a Radio Shack remote controlled airplane controller to work. I got forward/back/up and down.
Old Sep 20, 2001 | 02:54 PM
NickStam's Avatar
I'm thinking about swapping a John Deer into my car. any thoughts on this?
Old Sep 20, 2001 | 02:56 PM
Sonic's Avatar
A turbodiesel will fit, butthe turbo has to go where the radio is now. Anyone know where I can mount the new radio?
Old Sep 20, 2001 | 03:40 PM
armin4
to put a 300z engine in, would a rear wheal drive conversion be required?
Old Sep 20, 2001 | 03:44 PM
Sonic's Avatar
Unless you can figure out how to flip the engine over 90 degrees and still get it to fit under the hood.
Old Sep 20, 2001 | 03:46 PM
Jeff92se's Avatar
I'm needing a caw
I've done it. Actually it's 45 degrees. I usually make left turns anyway
Old Sep 20, 2001 | 03:48 PM
Sonic's Avatar
Old Sep 20, 2001 | 04:49 PM
NZ Max's Avatar
Rear mount conversions are quite easy.
Old Sep 20, 2001 | 05:34 PM
Kashoggio's Avatar
cant do it! way too much power. I would recomend doin the flinstones conversion. Much better off the line
Old Sep 20, 2001 | 05:39 PM
NZ Max's Avatar
i think the johnny conversion would be alright. guess you could use you max to " feed out ". youd have to turn the 4wd on though.
derekinthez
Nov 13, 2022 04:00 PM
fastcarny
Oct 6, 2015 10:42 AM
seesole
Sep 14, 2015 12:38 PM
I<3 A32's
Sep 10, 2015 11:07 AM
