taking out the center console
Old Oct 28, 2000 | 09:10 PM
Supa Lao's Avatar
Anybody have any pics on how to do this. I lost my crutchfield for my car, and I don't know how. I want to change my climate bulbs. I heard the air vents and clock pop out. But how do I pop these out? I know I can just pop out the cover by the shifter.
Old Oct 28, 2000 | 09:22 PM
Yellowbrother's Avatar
my 95 max gle:
1. two screw in the back of the console.
2. if auto: unsnap the cover on the shifter.
3. disconnect cig liter.
4. two screw on the front after removing cover.
5. screw on the ashtray.
6. two screw at the bottom of the radio
7. unsnap the air vent.
8. two other screw on top.
i believe this is all the step. not sure if i left something out or not. if i helped then coo, if not then at least i tried right?
Old Oct 28, 2000 | 09:33 PM
Supa Lao's Avatar
Gonna do it tomorrow after football. I'll let you know how it looks Doug.
Old Oct 28, 2000 | 09:43 PM
Supa Lao's Avatar
Thanks a lot Doug. I'll go out and get more bulbs then I get that done, get the one's on the door, and the dome. Man, my car is gonna be so ghetto or ricer w/ all this blue lights and neons.
Old Oct 28, 2000 | 10:05 PM
Cumalot's Avatar
Nice sig Doug!
Old Oct 29, 2000 | 08:24 AM
Botos's Avatar
Heh... But do you have the neons under the car so you can turn off the lights and look like a UFO cruising down the street?
Old Oct 29, 2000 | 01:30 PM
96BLUMAX's Avatar
Whats a good place to get the neons for under the car and how much do they run for?
Old Oct 29, 2000 | 01:40 PM
ny96max's Avatar
i dont think they can be done!
hey guys, i tried doin the light for the climate controls, it CANNOT be done!! neither can the ones on the doors, i think they are all LED bulbs ore something, not the 194 bulbs. Let me know if you guys get them done.
NY96MAXSE
Old Oct 29, 2000 | 02:50 PM
Supa Lao's Avatar
I took it out. And I don't think you can change those bulbs. I'm not sure what kind of bulbs they are in that thing. I started to take the climate control thingy apart from behind, but I got scared and didn't finish it. I don't have neons on the outside of the car. I have it under the dash on the driver and passenger side, and under the back seat. I would get the neons on the outside if I could drive w/ it on But since it's illegal to drive w/ them on, I don't think I will get them. I know you can get the neons from http://www.autotoys.com
Old Oct 29, 2000 | 02:53 PM
GarthG's Avatar
Let me know if you suceed in doing this, I have 2 lights that are burned out, one behind the hazards and one behind the fan switch. I can't figure out for the life of me how to find the bulb on the switch and I can't get the big fuse type thing out from behind the hazard light, I have pressed the button and such and pulled hard, and it won't come out. . . If anyone has any suggestions or help, I would be glad for any info.
Old Oct 30, 2000 | 06:04 AM
AntGVR4's Avatar
okay
sheesh the light behind my fan switch is burned out too..
and i'm almost sure it's possible to change the bulbs behind the climate control and the shifter light..
i was supposed to do it this past weekend but oh well...
looks light this weekend ...i'll let you know how it goes..
Ant
Old Oct 30, 2000 | 08:48 AM
ny96max's Avatar
goodluck
i tried taking apart the climate control piece. It is very well sealed up and impossible to take apart. No way was i gonna rip it apart and risk breaking it just for blue bulbs. My advice is to leave it alone!! or check your fuses or call up Nissan Parts and ask them what they would do if the light goes out.
Old Oct 30, 2000 | 10:39 AM
GarthG's Avatar
I went to a dealship and asked them about it. . . Said something like they would have to charge me for an hour of service, $70, and I said screw it, I don't need the bulbs that bad.
Old Oct 30, 2000 | 01:01 PM
Supa Lao's Avatar
$70, screw that. I don't need them that bad. I'll just keep it looking like this. That climate control does kinda look tricky to take apart.
Old Oct 30, 2000 | 02:40 PM
GarthG's Avatar
You might have a better dealership than I do. . . I know they did it for free on my Toyota when I needed help with that. . . Although Nissan's customer service isn't known for being that good as we all know.
Old Oct 30, 2000 | 05:09 PM
mo'max's Avatar
Center consol
I got it all the way apart yesterday. It's pretty easy. (95 SE 5sp). I was also able to get at those little nasty led's that lite up the climate buttons (for the manual climate control). I fixed that pain in the a$$ dimmer thing on the clock while I was in there. I'd recommend that if you haven't done it yet. Does anyone still need help?
Old Oct 30, 2000 | 06:23 PM
GarthG's Avatar
I still need help. . . Have the exact same car as you as far as the dash goes. . . I can get it apart, but I can't get to the bulb behind the A/C fan switch (Can't see it or find it). The other one will just require a lot of strength as I know where the bulb is, I just can't get the fuse/switch thing off of it no matter how hard I try.
Old Nov 12, 2000 | 05:41 PM
mo'max's Avatar
Climate bulbs
I've successfully done this (bulbs for 95 SE 5sp fan and climate buttons) and it's not really that hard. If anyone is still interested, let me know and I will write up some instructions. It'll take me a day or so (it's not hard, just long and detailed).
btw: Neither of my bulbs were burned out. They were loose in their seating (bad design IMHO). Thank God 'cause after getting a look at them I realized that I had never seen anything like it before and have been checking pepboyz, advanced auto, etc ever since and have not seen exact replacements. I've seen similar, but not exact. Looks like it might be a factory purchase if they're burned.
Old Nov 12, 2000 | 11:30 PM
party_boy's Avatar
neon under the car?
yeah its possible. i;ve seen a lot of mexican low riders do it. very illegal though. check lowrider magazine. i;m SURE they would have an ad for it. i;d suppose also it would be a kit with a relay,, power cord, light assembly, damage shield, some sort of springs to float it and a switch. personally i think it looks gay but hey whatever floats your boat.
Old Nov 13, 2000 | 09:15 AM
miked
center console
Go to installdr.com
I used their site when I installed an after market CD stacker on my Bose and it had detailed descriptions and photos. the place to start on the center console is GENTLY prying off the top vent and clock (on the bose equiped 97 anyway), good luck
Old Nov 13, 2000 | 03:58 PM
Black95Se's Avatar
mo'max, write us up some instructions i'm sure someone will post them on the web. I'm interested in doing this cause i'm going for all blue lights to match my head unit. (BTW who has a digital clock and digital climate controls that are blue like in the 95 nissan brochure?)
Old Nov 13, 2000 | 08:18 PM
piopremier's Avatar
colored bulbs
Just wondering where you guys get the blue bulbs for the gauge cluster
Old Nov 14, 2000 | 01:31 PM
BluethingSE's Avatar
piopremier, you can get them almost anyplace. I've got polarg hyper whites and a super orange.I've heard that you can get them at Pep boys/autozone> almost every aftermarket website online that has bulbs has colored bulbs...194's
Old Nov 14, 2000 | 07:25 PM
mo'max's Avatar
Center console
I've started writing it up. it's long 'cause it's detailed. I've forgotten a few details cause i went on vacation right after I did it. I may have to wait for the weekend and disassemble it again. sorry for the delay.
Old Nov 14, 2000 | 08:05 PM
GarthG's Avatar
Re: Center console
Write it up when you can. . .It will be a big help for those of us who can't figure it out for the life of us.
Old Nov 14, 2000 | 08:14 PM
MaximaMan's Avatar
LETS SEE SOME PICS!!!!!!!!!!!!!!!!!!
The people on here say they have done, lets see some results, i am going to do the mod, but i wanna get a good color, i have an SE right now, so basically any color looks good on the white, but i want something WAY UNique/cool
lets see some pics guys!
Old Nov 14, 2000 | 08:34 PM
GarthG's Avatar
He isn't posting a how to on changing the color on bulbs, it is more a how to change the bulbs in the dash of a 95-99 maxima. . . If you have looked at it, it is kinda difficult. . . I can't figure out how to even get to the bulbs behind the A/C controls.
Old Nov 19, 2000 | 04:34 PM
mo'max's Avatar
Center Console Instructions
OK...many of you have written to ask for me to write up instructions for changing the bulbs in the climate control unit (fan switch, a/c button and selector buttons). Sorry for the long wait, but I've finaly finished it. It's kinda' long, but I thought too much was better than too little. Most people will be able to skip through it. I'd like to post it on the site somewhere for others to take advantage of, but I don't know how to do it. Maybe someone can help me there. Right now Adidas_Boy is testing the instructions out for usability and to make sure I didn't make any mistakes before it gets posted. I have it in a Word doc. Email me if you'd like a copy before he's done testing them.
enjoy the ride !
Old Nov 20, 2000 | 12:50 PM
GarthG's Avatar
Here is the link to the DOC file that Mo Max wrote up. . . It is very good and very detailed. I was able to follow it with no problems whatsoever. He is right that you won't be able to find replacement bulbs easily though. . . I am wondering if you can just change the condom thing color to make them different.
http://web.csuchico.edu/~ggross/bulb.doc
Old Dec 2, 2000 | 11:22 AM
mo'max's Avatar
Replacement Bulbs (Center Console)
I was able to procure some bulbs from Nissan. The part numbers are as follows:
Fan switch: 27545-40U05
A/C and 6 Buttons: 27545-40U00
all three cost under $5.00.
I'm still working on getting replacements for the Hazard and Defroster (there are 3 total: 1 red, 1 blue, 1 Amber). The Nissan dealer that I got the other bulbs from said that you can't buy these as separates.
Old Dec 2, 2000 | 09:51 PM
mo'max's Avatar
Adidas_boy - I fixed the lights on my hazard switch and my rear defroster. Thanks to an earlier post by amixam69 I was able to get replacement lamps. He found them at radio shack p/n 272-1092C (I paid 1.49 ea. for a pack of 2 lamps). Let me know if you are still trying to fix yours.
Old Dec 3, 2000 | 03:30 PM
GarthG's Avatar
That's good info to know. . . My knocking on the dash trick worked for my hazard switch and it turned right on. . . I think it is funny that that works. If it didn't I don'tr know if I could even get to the bulb as I couldn't get the fuse type thing out of the socket. . .
TKHanson
Nov 24, 2018 01:39 AM
gigabyte
Jan 6, 2017 06:05 PM
