RPM's rising intermittently
Hi guys! When I'm stopped at a light, my RPMs rise intermittently to 900-1000 RPM. The engine will rev like this for approx 10-15 seconds. Sometimes when I start the car, the RPMs rev to 2000 but only for a few seconds. Do you have any suggestions as to what the problem could be.
The car is a '96 automatic GXE.
Don
Don
Re: RPM's rising intermittently
Don
Don
Other sources of False Air include a damaged or disconnected vacuum line, a stuck-open Positive Crankcase Ventilation valve, and a leaky power brake vacuum line check valve.
False Air is one of those problems which does not set a Diagnostic Trouble Code and turn on the Malfunction Indicator Lamp.
When the engine reaches normal operating temperature the electronic engine management system goes into Closed Loop mode. The Oxygen Sensors sense the concentration of oxygen in the exhaust stream. The Engine Control Module (the computer) uses the signals it receives from the Oxygen Sensors to adjust the fuel mixture. False air puts extra oxygen in the exhaust gas. The ECM responds by directing the fuel injectors to correct by supplying extra gasoline. More air plus more fuel equals higher RPMs.
We commonly refer to the accelerator as the "gas pedal". With modern fuel injected engines this has become a misnomer. It is more properly called the "air pedal".
jmlee44
10-02-2022 02:13 PM
Unclejunebug
04-02-2016 05:42 AM
Need help
23
10-02-2015 08:56 AM
