Ecu 1005
Read this and find the code that you got. That one does not sound familiar:
http://forums.maxima.org/showthread....threadid=45274
A search (gasp!) for "1005" revealed this:
1005 is EGRC Solenoid valve
The majority of my information about Diagnostic Trouble Codes comes from my '99 Maxima factory service manual. Unfortunately, DTC 1005 is not in that book. Starting in '99 the Maxima engine uses a step-motor type of EGR valve and with that change, the DTCs changed.
The Chilton and Haynes manuals provide a little information about the EGR Solenoid Valve.
The test procedure for this part is found in the Chilton repair manual (page 4-11) and the Haynes repair manual (page 6-20). Test the valve and replace if necessary.
This malfunction is not an emergency but should be resolved fairly soon (7-10 days). An inoperative EGR valve may result in engine pinging and a variety of driveability complaints.
ECU 1005
This error code stands for EGRC Solenoid value. But
I am not sure I should fix this problem
with this part EGR - Exhaust Gas Recirculation
EGR Valve, OE Numbers 14710-40U00; AEY77-69; Orifice Number N/R; Use Gasket {EVG51}; Use EGR Tube Gasket {EVG66}
cost between 110 to 120. So I hope somebody can
give me an opinion before I waste my money on my 96 max
Thanks in advance
Thanks in advance
Omar Abdurrahman Siddiqi
Aug 26, 2016 05:18 PM
BLACKKILA.GTR
Sep 29, 2015 11:23 AM
QueensMAX
Sep 15, 2015 04:14 AM
