Weird noise when I turn the AC on
Old Sep 27, 2001 | 12:27 AM
ionicmax's Avatar
Former Sponsor
Hi:
When I turn the AC on I can here a grinding noise like a "rrrrrrr" coming from the area where the belts are. When I turn the AC off the noise goes away.
What could this be?
Thanks!
Old Sep 27, 2001 | 07:00 AM
Toolrocks's Avatar
I would assume it is either the air compressor or the air compressor clutch. Your compressor isn't engaged (running) until you push the A/C button inside the car. Once you turn it on, the a/c clutch links the pulley that the belts are spinning and the compressor. This then causes the a/c compressor to spin internally. My car is doing the same thing. I am going to bend over and take it to the dealership. I am sure they will just want to replace the entire air compressor which will probably be expensive. You might be able to just replace the clutch though. I don't know enough about it to tackle it. Good luck.
Old Sep 27, 2001 | 09:46 AM
ionicmax's Avatar
Former Sponsor
Thanks!!
So I can probably keep on driving my car without turning the AC on?
Old Sep 27, 2001 | 11:16 AM
My97Maxima's Avatar
My compressor made a similar noise for about 7 months. The A/C worked fine, the compressor was just noisy. It got a little worse so I replaced the compressor. 250 for a remanufactured compressor at Auto Zone and 150 for the install. This one is much quiter, however not as quite as I would like. I think a lot of Maximas have noisy compressors. Hope this helps.
Old Sep 27, 2001 | 01:37 PM
Toolrocks's Avatar
Re: Thanks!!
I don't know if I'd advise that. Here's why - it could be possible that whatever is grinding may seize and lock up. If that were to happen your belt would heat up and break, possibly leaving you stranded. I would get it properly diagnosed and re-evaluate from there. Hope this 2 cents helps. Good luck. Mine goes in for service next Wed. I'll let you know what they say about mine.
pears
Sep 18, 2015 05:25 AM
lrb6805
Sep 17, 2015 04:49 PM
LtLeary
Sep 14, 2015 12:33 PM
thenewguyy
Sep 12, 2015 11:12 AM
bennuss
Sep 11, 2015 05:55 AM
