Redline Tranny Oil
Old Oct 29, 2000 | 07:25 PM
black96se's Avatar
I remember hearing good things about redline manual transmission oil (how it eliminates notchy shifting, even when cold).
I finally went to check it out at a local performance shop and they wanted $21 Canadian for a quart and the Maxima needs 4-5 quarts! Is it really worth it? Any comments would be appreciated.
Old Oct 29, 2000 | 11:21 PM
Slickismax's Avatar
Umm, Courtesy Nissan in Dallas sells it for $6-$7 a quart. Its worth it, but not for $21 a quart! Try to find it somewhere else cheaper.
Old Oct 30, 2000 | 01:20 AM
Eric L.'s Avatar
Um, it's $21/quart Canadian, which translates to around $14/qt US. Man, that's like US$6 markup over the normal price! Still way too expensive.
Even if you order direct from Redline, they will charge you less!
Old Oct 30, 2000 | 06:04 AM
humaras's Avatar
tranny amount
I thought the tranny needed 11 quarts if you were going to replace everything--drain and flush instead of just a flat out drain and refill--which doesn't get everything out.
if it is 7 dollars a quart--multiply that by 11 and that is about 77 for the entire tranny job.
whewww...
btw, is it just me or the automatic shifts notchy as a normal thing?
Old Oct 30, 2000 | 08:07 AM
dwapenyi's Avatar
Re: tranny amount
I think you may be confusing the issue here. You have an auto, he has a stick. The sticks take Red line MT-90 and the autos use Red line MTL. The capacities are quite a bit different, too.
Speaking from Experience, I have MT-90 in my 5 speed and the difference was like night and day! The 1st day I drove it I felt like something in my tranny was really loose. The shifting was wickeldy easy! Now I'm use to it.
DW
whewww...
Old Oct 30, 2000 | 12:06 PM
Eric L.'s Avatar
Re: Re: tranny amount
Actually, the automatics use Redline D4 ATF. Normal Redline ATF (which is Dextron 2E) works, but why not just get the D4 which is better.
DW
whewww...
Old Oct 30, 2000 | 12:48 PM
petenycmax's Avatar
Re: Re: Re: tranny amount
DW
whewww...
So how many quarts of the Mt 90 are needed for a complete flush and fill for a 97 5 speed?
Old Nov 3, 2000 | 05:15 PM
Custommaxima.com
RedLine Oil
Anyone know how often to change it. I got Redline mt-90 in mine.
Old Nov 3, 2000 | 05:18 PM
SmoothMax's Avatar
OG
Maybe this is a stupid question, but I assume they sell redline for autos too right?
Old Nov 4, 2000 | 08:59 AM
Eric L.'s Avatar
Yeah, AUTOMATIC Maximas use Redline D4 ATF. 5-spd Maximas use Redline MTL. Check http://www.redlineoil.com for more info.
user 11122324
42
Jul 18, 2022 03:35 PM
mclasser
22
Nov 12, 2020 01:58 PM
05RLS2
Apr 14, 2016 11:49 AM
fx4five
Oct 18, 2015 06:57 PM
fx4five
Oct 1, 2015 04:58 AM
